Need input - SSI Observations
Hi,
I recently installed SSIs on my 1977 911 S with a 2.7. A couple of things:
1. I purchased an induction tool that heated the nuts to red-hot, wow, what a difference on removing the old nuts. They just easily turned off with no broken studs, would recommend 100% for anyone else doing this type of work.
2. My old headers didn't easily slide down and I ended up having to use a hacksaw to cut one of the tubes for them to come off. Straight to the garbage for the old headers.
I ended up buying copper nuts, the barrel nuts and used anti-sieze so I'm hoping it won't be an issue in the future when I remove the SSIs.
I would appreciate your thoughts on the following:
1. I had to reuse the old spacers, basically small tubes that went over the studs. Is that normal?
2. For both the barrel nuts and the regular nuts, I just hand-tightened them. The regular nuts, I didn't receive the SSI tool so I used a 13mm open ended wrench. The barrel nuts I did buy a 8mm hex but it cam with a ball-end and that didn't get the nuts as tight as I would have liked. I did buy another 8mm hex socket that arrives tomorrow and I'll try to torque down the barrel nuts to 18 ft-lbs.
The biggest observation is that the SSIs are quite a bit louder than my previous headers. I'm thinking it is because the nuts aren't torqued properly but I don't know and would appreciate your input. It almost sounds like an open header but it is hard to describe. I'll see if I can post a video but I'm not sure how to do that.
I'd appreciate your thoughts.
Old 11-16-2024, 11:10 AM
tops911's Avatar
I put SSIs on a 78 SC many years ago, something like 20 years ago. I used a Mapp gas torch to heat the nuts and I did a couple cycles of heating and cooling and they came off no problem. I used only copper (plated?) nuts with nickel anti seize because of the higher opperating temperature. The nuts had a smaller 12mm head rather than 13mm. I just used a 1/4 inch ratchet to tighten the nuts and made sure not to over tighten. I did not have or use any spacers over the studs. I think they may have been a little noisier but the heat was awesome.
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel
Old 11-16-2024, 01:02 PM
1988 Carrera
shadowjack1's Avatar
Every time I do an oil change I work the nuts on the exhaust system. Just loosen them a little bit and retighten. Never fear them again.
88' Carrera
79' SC gone (lost to Katrina)
75' Targa gone
72'914 gone
72' 914 gone too
Old 11-16-2024, 02:44 PM
