ITB Install - Linkage Question
Hi,
I running into a problem connecting my Closed Course Motorsports ITBs linkage to my existing linkage. Here is a picture: ![]() As you can see the old vertical linkage has a push-on connection. The replacement uses a nut and bolt inserted into a ball joint. I can't connect the new linkage and need to replace the vertical part but i'm not sure where to find it. Any ideas? |
Big help from Al Kosmal, he pointed me to a solution!
Thanks Al |
