Alternator wiring
I am replacing alternator and voltage regulator in my 74 911 with a Bosch alternator with built in regulator. I’m fairly certain I know where to hook the hot red wire and blue wire that goes to the instrument panel. I cut and capped the black voltage regulator wire. I’m not sure what to do with a white or faded tan wire that remains. I took pictures of the original wiring but they’re not helping me. I’d appreciate any help I can get.
Ron from Indiana
Old 12-15-2024, 08:22 AM
PCA Member since 1988
"Tan" should be brown. That's the ground wire. It doesn't do anything with the VR removed, but I would ground it to any convenient nut/bolt/screw.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-15-2024, 02:38 PM
Thanks for your help. If I understand correctly the only important connections are red to B+ and blue to D+. Not sure but I also take brown to any place I can use for ground. Wiring diagram says D- but maybe that’s not necessary.
Old 12-15-2024, 06:32 PM
When you say ground it to any nut bolt screw are you saying any nut bolt screw on the alternator or somewhere else close to the alternator?
Old 12-16-2024, 06:08 AM
Either the case of the alternator or a stud/nut/bolt on the engine.
Old 12-16-2024, 10:58 PM
Thanks again.
Old 12-18-2024, 09:19 AM
