Alternator wiring
I am replacing alternator and voltage regulator in my 74 911 with a Bosch alternator with built in regulator. I’m fairly certain I know where to hook I the hot red wire and blue wire that goes to the instrument panel. I cut and capped the black voltage regulator wire. I’m not sure what to do with a white or faded tan wire that remains. I took pictures of the original wiring but they’re not helping me. I’d appreciate any help I can get.
Ron from Indiana
Old 12-15-2024, 08:12 AM
Ron,
Is the white or faded tan wire a ground?
B+ = red wire
D- = brown wires (ground 2 required)
61 = blue wire
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 12-15-2024, 11:17 AM
I believe so. When I disassembled things a second broken white wire was laying on top of the block. I didn’t have any brown wires. But I do see two brown wires feeding the regulator.
Old 12-15-2024, 12:40 PM
I’ll try to attach a picture of my replacement alternator and my regulator. Not sure what to do to take it out of service.
Old 12-15-2024, 01:00 PM
I’ve spent almost an hour trying attach pictures. I give up.
Old 12-15-2024, 01:29 PM
ROW '78 911 Targa
timmy2's Avatar
Click advanced when you want to reply and scroll down to attach.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 12-15-2024, 01:42 PM
PCA Member since 1988
Ron, see my reply on the other thread you started. Then delete that thread and stick to one thread. Brown (not tan) is ground.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-15-2024, 03:17 PM
Thank you. I’m struggling navigating our site. I’ve tried to delete the duplicate but can’t pull it off. Only option I find is to edit it. Also struggling to attach photos. A helpful member says to start with “advanced reply”. I can’t even find that option.
I’ll keep trying
Thanks again.
Old 12-15-2024, 06:23 PM
ROW '78 911 Targa
timmy2's Avatar
Right beside the yellow post quick reply it says go advanced.
You cannot be in mobile view.
Dennis
Old 12-15-2024, 08:30 PM
ROW '78 911 Targa
timmy2's Avatar
Here you go:
Click right yellow box to get to this screen.
Type something then scroll down and hit the blue button.
Find your photos, click upload, wait for a check mark to appear and select done.
Files must be under 5 mb
You cannot add one at a time or a few if small enough.
First screen:
Second screen:
Dennis
Old 12-15-2024, 08:36 PM
al lkosmal's Avatar
alt wiring with internal reg
RGruppe #669
http://www.x-faktory.com/
Old 12-16-2024, 08:32 AM
Thank you. I finally see the Bulletin 1.
Old 12-18-2024, 09:23 AM
