Adhesive for loose vinyl?
Much of the vinyl in my 911SC is coming loose, to some extent. It’s pulling away from sections of the door cups and parts of the targa bar. Has anyone else had this issue? Is there a recommended solution for it?
Old 01-13-2025, 07:05 PM
3M Adhesive. Also can be had in black. https://www.3m.com/3M/en_US/p/d/b40069421/
Old 01-13-2025, 07:23 PM
PCA Member since 1988
Agree, 3M weatherstrip adhesive.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-14-2025, 12:22 AM
I use this stuff when I’m not spraying, cheap and available everywhere, good for headliners too.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 01-14-2025, 05:59 AM
Danimal16's Avatar
DAP Wildwood Landau Top and Trim Adhesive
This is the best stuff, better than the 3M sprays. It is pricey and comes in aerosol and gallon cans.
Dan
Old 01-14-2025, 07:40 AM
^^^ this. The weldwood stuff is great for adhering vinyl or leather. Lasts a long time.
Pricey but worth it in the end. Good luck w. repair.
Old 01-14-2025, 08:13 AM
And you can pick up smaller cans at the big box stores
Old 01-15-2025, 07:09 AM
D idn't E arn I t
RANDY P's Avatar
3rd for Weldwood Contact cement - just make sure you put it on real thin on both sides, let it sit and air for about 10 minutes before pressing together.
You basically get only one shot tho, it's wicked strong stuff.
rjp
In the movies only bad guys sleep in king size beds.
Old 01-15-2025, 11:54 AM
D idn't E arn I t
RANDY P's Avatar
PS ya don't waste your time with 3m over the counter on vinyl- any of it. It'll get hot and pull away.
Weldwood- either landau top or contact cement.
Old 01-15-2025, 12:04 PM
I use Permatex Super Weatherstrip adhesive, works great for headliners and vinyl. Inexpensive, available at your local autoparts store.
Weldwood is great as well, Walmart usually has it in small 16 oz cans .
H
'77 1973 911RS Backdate, 2.7 liter w/webers
'70 911ST , 3.2 liter '82 '74 911 IROC Tribute , 3.0 in progress
'75 911 RSR street car in progress
'77 930 Replica '75 993 GT2 EVO race car , 3.6 TT
'79 928 5 speed money pit in progress
Old 01-15-2025, 12:17 PM
Arrow
I used weldwood, the good stuff. Be careful and follow the instructions.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 01-15-2025, 02:12 PM
I have always had good luck with yellow 3M super weatherstrip adhesive, so long as I follow the instructions. For some reason I think the yellow is better than the black.
Old 01-15-2025, 05:15 PM
DAP Weldwood contact cement. Great on vinyl. Like RandyP says….ya get one shot.
Mark
1971 911E targa
Priors:
1955 Speedster, 74 911 coupe, 69 911T coupe, 74 911 slant nose w/928 lights, 03 911 Turbo
Old 01-16-2025, 05:58 AM
