Discseven's Avatar
Anyone with 3.2 running 964 40/40 grind cams, SSIs, Dansk 2-in-1-out muf?
If you're running this 3.2 config, what's your city mpg?
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 12-22-2024, 12:03 PM
Cairo94507's Avatar
I ran a 3.2 with Motronic injection, 964 cams, Steve Wong custom chip large tube (Ben's) SS heat exchangers and a Dansk 2-in 1-out muffler and routinely got about 23 MPG. I recently swapped in a '95 3.6, stock with the exception of a Steve Wong chip and the same heat exchangers with a Sport Dansk muffler and now get about 27 MPG. Runs great with plenty of power.
'71 914-6 #0372
'17 Macan GTS
Old 12-22-2024, 03:21 PM
Discseven's Avatar
Cairo...27...is that your city mpg?
Karl ~~~
Old 12-23-2024, 04:52 AM
Schulisco's Avatar
See my car and it's specs in my signature. I can confirm a mileage between 19-24mpg. Mixed conditions, so a bit autobahn, country roads and a bit more(but not only) city driving with almost no traffic jams. Lambda-CIS works, I use a heated oxygen sensor from the 3.2 Carreras.
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 12-23-2024, 07:04 AM
Cairo94507's Avatar
27 MPG was with city and freeway combined over about 225 miles if I recall correctly. I typically check my mileage every time I gas up.
'71 914-6 #0372
'17 Macan GTS
Old 12-23-2024, 07:57 AM
Discseven's Avatar
Thank you guys. You both are seeing good numbers as far as I'm concerned. I have a mystery in hand... 10-12 city and 27 highway on a fresh 3.2 engine with the noted mods. I failed to mention pushing overlap to 1.45.
Karl ~~~
Old 12-23-2024, 11:37 AM
Schulisco's Avatar
Do you run the engine with CIS or Motronic? Which one exactly? US or ROW version? Oxygensensor? Did you already checked the mixture?
Old 12-23-2024, 12:30 PM
Call 911
dkirk's Avatar
Karl, I'm running the exact setup you mention on my 3.2 liter, '88 Coupe with Motronic FI. I don't do much city driving, car is mostly driven on back country roads. My 964 cams are timed per the 964 engine spec. I'm running a custom Steve Wong chip. I always log my mileage when refueling and it averages out to 25 mpg. Highest I've ever recorded was 26.5.
Dave Kirk
My Porsche restoreth my soul.
Old 12-23-2024, 06:17 PM
Discseven's Avatar
Schilisco... Motronic. USA. DME has been tested... no faults. Have dual 4.9 Innovate wideband, LC-2 units. LogWorks is my "gauge." Pulls hard & clean to redline. Zero hesitation through all rpm. Clean idle. Great performance and city mpg sux. I've been through everything I can imagine. Did find parking brakes were dragging. Rebuilt those and city went from 10 to 12 mpg. Recent logs below are Lambda...
Green = 1-2-3
Blue = 4-5-6
Red dot-dash = 1.0 Lambda / Stoich
WOT Blue dot-dash = 0.89 Lambda
WOT:
Steady 3000 rpm in 4th gear:
Warm idle, 850 rpm, mixture screw 4 and not quite 1/4 turns out. Blue dot-dash = 0.96 as target Lambda for 1-2-3 side:
Credit for suggesting these tests and defining targets for WOT (0.89) and warm idle (1-2-3 = 0.96): Sal / "scarceller" ---- much appreciated Sal.
Engine's on target AFR-wise. So, were is the city-driven fuel going? There's also the oddity of 10-12 city and 27 highway mpg. One would think if the city mpg was low, the highway would follow suit.
I've been through fuel & engine components to the extent that I can help but return to the 964 (40/40) cams with 1.45 overlap, SSI, Dansk muffler combo as these are what have obviously changed since the engine was doing 18 city (and I don't recall what highway was but it was good.)
Thanks Dave. I drive mostly city so 10-12 mpg is an attention getter on my end. I know my ECU has a current stock chip. 10-12 is city only mpg. 27 is highway only mpg. I've driven these tests separately and a number of times to be sure of the numbers.
Karl ~~~
Old 12-24-2024, 02:44 AM
