RickKlem's Avatar
Location: Seale, Alabama (25 miles south of Auburn, Al.)
Part number for cupped washer on drive shaft needed!
There is a cupped washer that is placed on the drive shaft before you install the cv joint. It is the washer that is between the CV joint and the flange for the boot (Picture below).
Pelican claims the only part number that they show for this item is the complete shaft assy. They ask me to post it here ,just incase someone knows the part number for just the washer. Or does someone have two (new or used) ones that they are willing to let go of?
Rick
Old 07-02-2003, 10:35 AM
derek murray's Avatar
The schematic below is for the year 1980. It does provide a part number for the cupped washer, 14b. Although this may not be for your particular year of car, it is at least a starting point.
Regards,
dm
'70 911S 1002938
'70 Ducati Mark 3D 350
Old 07-02-2003, 11:23 AM
KTL KTL is offline
Schleprock
KTL's Avatar
What year is your car Rick?
The SC's (78-83) and the Carreras (84, some 85) use part # 901.332.311.10
The 930's (75-86) and Carrera TurboLooks (84-86) use part # 901.332.312.00
The 911 cars earlier than 77 appear to vary based on VIN #. Not real sure what the deal is with that. Some use the 311.10 and others use the 312.00. Weird.
This is all according to PET.
Hope that helps?
Kevin L
'86 Carrera "Larry"
Old 07-02-2003, 11:29 AM
RickKlem's Avatar
It's a 77 911S so i'm not sure if the one from the sc will fit or not.
Rick
Red 1977 911s 3.0L (27230)
2013 Base Cayenne 3.6L
Old 07-02-2003, 02:12 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Give me your VIN # and i'll see what PET says you need.
Kevin L
'86 Carrera "Larry"
Old 07-02-2003, 02:27 PM
