SC is reading 13 volts at the battery at idle — how much time do I have left?
The battery light on my SC has been lit basically since I inherited the car and got it back on the road last year. I never have any issues starting it, so I’ve not really looked into it that seriously.
Since I was working on the car earlier today, I decided to test the voltage at the battery when it was idleing. It’s at roughly 13 volts. When I turn the headlights and high-beams on, it goes to around 12.4. I know that it’s supposed to be at 14-14.3 volts if the alternator is running properly. That would seem to suggest that it’s on its way out. Anyone have any idea what sort of timeframe I should expect? Is this something that has to be addressed immediately? Or could this be something that just can be managed for a while? |
Most supposingly the alternator is dying. Resolve the issue asap.
The alternator on a 911 is basically the same as on other cars...and so the error lookup process. https://www.hella.com/techworld/sg/Technical/Car-electronics-and-electrics/Starting-and-charging-system/Checking-the-alternator-41623/# Quote:
More info: https://youtu.be/K4f6Mu4GV-w https://youtu.be/Nm1oGok5Ppo https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/20-Alternator_Replacement/20-Alternator_Replacement.htm https://forums.pelicanparts.com/porsche-911-technical-forum/54271-alternator-update.html https://forums.pelicanparts.com/porsche-911-technical-forum/709712-911sc-alternator-update.html Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
It's a 914 ...
You're probably right, but it's worth doing a load test on your battery before replacing the alternator. Easy enough to do, I think some Autozones etc. do it for free. Or just test the alternator.
One quick question about alternator replacement. Is there a torque value for the band that holds the housing in place? I don't want to crack the housing with to much torque on the Allen head bolt that tightens the band around the housing.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
M6 6,5Nm M8 12Nm Taken from the tech spec book for the 911. Thomas
Might want to clean the ground points at the battery and trans to body. Both ends.
