URO Cylinder Head Temp Sensor
Hi,
Rebuilding my 1989 911 3.2 and need to replace the CHT sensor that I cut the wire on during engine disassembly.
When I was researching upgrading to the 2 wire units with ground, people were saying they were roughly $100, so I wasn’t concerned about cost. Now I see the Bosch are unavailable, and the Porsche ones are $250-300.
Has anyone successfully tried the URO? They are < $100.
Really frustrating, as my one wire was working fine. I wish I would have done a recent price check before cutting wire.
I have also heard of people using 964 CHT in 3.2 Carreras. Can anyone confirm they have successfully done this? 1/3 of the price. Alternatively, does anyone have the temp/resistance curve of the 964 sensor? The 3.2 Carrera map is in the forums.
Thanks,
Mark
1989 911 Carrera 3.2
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Old 05-23-2020, 08:32 AM
Originally Posted by Dauner View Post
Hi,
Thanks,
Mark
This is from the 964 service manual, can't see why the 964 CHT wouldn't work in
a 3.2.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 05-23-2020, 09:25 AM
Someone on RL says you can't buy a 964 CHT from Porsche anymore; only the 993/996 sensor is stocked. If you want to use it on a 964, you also need the connector kit to convert.
One guy reported that he bought a 993 sensor as it looked identical in the photos/diagram - but it was a different thread to the 3.2
Why don't you repair the one-wire lead you have? Or use the one-wire 914 sensor for $20.
It's a Bosch NTC (Negative Temperature Coefficient) sensor; same semi-conductor technology as the one on the 3.2. These are nominally 2.4K Ohm @ 20C +/- 5%. Check against the table uwanna posted.
'77 S with '78 930 power and a few other things.
Old 05-23-2020, 02:50 PM
sugarwood's Avatar
When someone makes a part supporting our cars, maybe give it a try. That way, they still keep making parts for our cars. If its bad, can you return it?
1986 Bosch Icon Wipers coupe.
Old 05-23-2020, 08:50 PM
Thanks guys,
Looks like I have a couple of options and some homework to compare curves. My current plan is to resolder the one I have and use as a plan B if I can’t find a reasonably priced used one. Will check out the 914 one.
Mark
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Old 05-24-2020, 06:59 AM
I have a URO sensor on the way, will update with my results.
Old 05-24-2020, 10:38 AM
Because doing a nightmare job twice sucks?
Old 05-24-2020, 10:49 AM
Red Line Service
Marc Bixen's Avatar
See my thread “More URO junk”
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 05-25-2020, 12:39 PM
It looks like the temp/resistance curves are identical in the 964 and Carrera 3.2 manuals.
Can someone please confirm that the threads for the 964 CHT sensor are M10? I can’t find this anywhere, including the part descriptions.
Other challenge is the connector and wire length. If someone can confirm they are the same, will save me time.
If there is an adaptor cable, I can’t find that available either.
Between Rennlist and Pelican, there is not one all inclusive thread that discusses replacing a 3.2 CHT with a less expensive alternative than the $250 Porsche one.
The inexpensive 914 CHT may work, but I can’t find the map, and I still have to modify connector. No big deal, but if possible I’d like things to look not super cobbled...
Thanks,
Mark
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Old 05-29-2020, 08:38 AM
Pelican Parts Vendor
UROParts's Avatar
Hi Mark, our Cylinder Head Temp Sensor 930 606 915 00 is now available, and we've sold 192 so far with no returns or complaints.
You might want to also subscribe to this thread: Verify my CHT sensor test results
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2
Old 05-29-2020, 09:02 AM
famoroso's Avatar
FWIW, I just picked up my '87 911 from Jae Lee / Mirage International yesterday. He rebuilt the engine to a 3.4, during which time he installed a new genuine Porsche CHT sensor. The car developed a hot start (technically a hot no-start) issue post rebuild. He swapped the previous CHT sensor back in. Problem solved. Brand new, in-bag, $267 Porsche CHT sensor was dead on arrival.
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 05-30-2020, 07:57 AM
UROParts
In More “URO” junk, page 3, you mention that there are three tiers of parts first tier, middle tier and top tier URO Premium. So what tier are the Carrera head temperature sensors? It's difficult to tell on price alone since the Bosch price was about the same as the URO price but about 1/3 Porsche price.
Originally Posted by UROParts View Post
Hi guys, here's some additional info about our history. https://apaindustries.com/company/about
We're definitely an American company, with our headquarters and engineering lab located in Southern California. Our parts are manufactured in many countries, including Taiwan, China, Thailand, South Korea, India, Pakistan, Germany, and the USA.
It's an oversimplification, but we basically have three tiers of parts. The first tier consists of sourced economical parts that are the exact same parts you'd get from other aftermarket brands, but we try to offer a lower price. The middle tier are parts we've developed in-house, which are typically higher quality than our competition but are still very competitively priced. An example would be many of our idlers and pulleys, which are equipped with high-quality, name-brand NTN or NSK bearings whenever possible. The top tier are our URO Premium items, which we painstakingly develop to be higher quality in materials and/or design than OEM, but sell for roughly the same price as OEM.
Examples of URO Premium would include the BMW water pump pulley mentioned above, which is made of aluminum instead of the fragile OEM plastic, or a variety of plastic cooling system connectors which we upgrade to aluminum. Or repair kits that allow you to repair an assembly instead of replacing it, such as some automatic shifter assembly components for Mercedes, or a vacuum seal kit that allows you to repair your expensive Mercedes or Volvo brake booster (installation video shown here). Or our Intake Manifold Repair Kit for Mercedes M272 V6 or M273 V8 engines, etc.
Old 05-30-2020, 05:51 PM
UROParts's Avatar
Hi Harold, this is an item we developed to match OEM, so it would be the middle one. It's not designed to be better than OEM, so it's not a URO Premium item (which can be identified by "PRM" at the end of our part number).
Old 06-01-2020, 12:24 PM
Thanks UROParts.
Old 06-01-2020, 05:20 PM
Just to close the loop, I did end up purchasing a URO CHT sensor. Engine is finished, installed, and I have 200 miles on it. URO product seems to be working fine...
Mark
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Old 07-12-2020, 07:55 PM
faulty sensor
Sadly, my uroparts sensor has a problem. I bought it to use on my efi conversion and now have a flaky temp reading... turns out the connection to the sensor itself is intermittent so I need to get a replacement.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 12-28-2024, 11:44 PM
fwiw
I used a URO in my 3.2, works fine. It's just a thermistor stuffed into a threaded housing. Not rocket science and certainly not $200+. My old 1-wire sensor was reading low across the board which would tend to be lean in theory. You almost buy the thing off the shelf at Mouser: https://www.mouser.com/ProductDetail/Vishay/NTCASCWE3152J?qs=%2FWiulJ9oly71tItYBKC28g%3D%3D
Old 12-29-2024, 07:28 AM
Grappler
Rodsrsr's Avatar
I've ran the URO sensor for the past five years and still working fine.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 12-29-2024, 08:56 AM
UROParts's Avatar
PM sent Mikedsilva, we haven't had any issues with these but let's get you taken care of.
Old 12-30-2024, 03:27 PM
fyi - URO Parts reached out to me here, and sent me a replacement. The new one works perfect.
The old one definately had some sort of break in the wiring (intermittent connection).
I think it's pretty amazing that a parts company, backs up their products so openly and supports the community in this way.
Thank you
Always learning.
Old 02-03-2025, 02:30 PM
