Bilstein shock info
I am utterly confused
I have communicated w/ Bilstein US technical dept. twice now once in 2019 and once this past week looking for confirmation In both, Bilsteins asserts that all 911 b6 & b8 for street use are digressive and that only the motorsports shocks like the 993 Cup shocks are linear. I don't know what to believe any more as all the dyno plots for street b6 that I have ever seen indicate linear
I would think that Chuck at Elephant Racing would have a shock dyno as he sells different shock setups in the Von line which I think are Bilstein and he would have applied info. Why would you go digressive for a street setup. Bob
I trust Chuck to be straight w/ info and he says linear for all I just don't know what to make of Bilstein Technical's response as it makes no sense and totally disagrees w/ what I've seen My 993 Cup Bilsteins were certainly linear and revalved to digressive by Bilstein San Diego before installation Bilsteins also say that they no longer service shocks and recommended Performanc Shock for any service or revalve
To understand digressive and maybe I don't. In what I think is rebound, as the car is lifting on that corner, the more aggressive that move, the stiffer the shock becomes during that action. My understanding. Bob
the characteristic are early ruse and then a nice flattening as piston speed increases ![]() here are 2 linear and 1 digressive for comparison, not the unlimited increase in damping force w/ increasing speed associated w/ linear, only Ohlins to my knowledge, adds a blow off valve to limit this ![]() here' s MCS 2way ![]() the thing ,I don't like about these curves is that they all use the computer to zero out the gas preload here's one w/o the base preload zeroed out, it better shows what's going on ![]()
BV, I happen to have a quote from Chuck here. Von level 2's per Chucks advice along with bushings and such, waiting for input from a shop I'll probably use. Might go for new spring plates as it will be quicker than sending mine out to replate. Give me a few months and I'll post. Bil rears now. PeteKZ will probably come drive it and give a third party opinion.
FWIW, I installed Chuck’s Vons shock on my 72 years ago as the sport and HDs were progressive and Chuck’s were digressive.
996 Coupe, 84 Euro Carrera, Cayenne S, BMW CS 30, 72 2002 Ti (gone) 72 911 Hot Rod, Healey 100M, Giulia 1300 Ti, Merc 280SE4.5 Colorado Grand 03-04-05-07-08-11-17-18 Tour Auto 04-05 RG #650 |
did you?
I base this mostly on this sort of shock dyno chart again gas pre load has been zeroed out and I wouldn't be happy w/ the exhibited digressive curve, though it is better than the comparison linear curves ![]() I do believe that Bilstein non Porsche 911 b6 may be digressive and suspect that the tech reps just didn't really investigate deeply enough even though I was inquiring specifically about '70s thru current Porsche 911 g body shocks
Part # for the B6?
I will scan and email the charts to you, Bill - It will be an honor to provide you with a chart/data for once. I wish I had your database... |
