German Blood
Germanblood's Avatar
CV joint c-clip
Does anyone know of a tool to get the c-clip off the tranny side side of the rear axel that keeps the CV joint on the axel? Bugger has no ears to use a normal tool. I am replacing the CV boot.
Old 02-17-2025, 05:04 PM
Alan L's Avatar
If it has no ears (internal or external) then it may actually be an E clip.
In which case a screwdiver slipped into the gaps will work.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-17-2025, 05:22 PM
Suspect you need to use Flat Snap Ring Pliers
Like these:
https://www.amazon.com.au/dp/B095M5NLL3?ref_=mr_referred_us_au_nz
Cheers
Old 02-17-2025, 09:05 PM
German Blood
Thanks. It has tapered ends and that's it. Dueling screwdrivers is seriously frustrating so I hope the tool works.
Old 02-18-2025, 04:34 AM
Those pliers should expand it a bit and let you insert a pick underneath the clip to ... destroy it. You will need replacement clip, or a circlip with ears.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 02-18-2025, 07:05 AM
