Which coilover?
I'm debating on going with coilovers for my 71. I am planning on going with this kit for the front: https://www.rsrproducts.com/product-page/bilstein-rsr-front-strut-assembly I'll be using 911SC aluminum trailing arms and wanted to know what would be the best rear coilover setup to go with?
1971 911T Irish Green Coupe
Old 02-21-2025, 06:24 PM
If you want to wait 3 years like I did to get mine from rebel buy them. If not still buy them just from anybody else
Old 02-21-2025, 09:39 PM
PCA Member since 1988
Why do you want coil-overs? Are you building a race car? For a street car, stick with the torsion bars.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-21-2025, 09:53 PM
3 years!?!?!? What was their excuse? Covid? The fact that I've already emailed them and called yesterday and crickets isn't a good sign. Now seeing this post definitely doesn't give me the "warm and fuzzy" feeling about them.
Old 02-22-2025, 05:06 AM
Covid. ChrisP pieced his together from a few vendors back then. I'm waiting on straight Von's but you can add springs later if you want to ditch the TB's.
Old 02-22-2025, 07:00 AM
3rd_gear_Ted's Avatar
Jrz
1980 911 - Metzger 3.6L
2016 Cayman S
Old 02-22-2025, 07:16 AM
Bill Verburg's Avatar
Originally Posted by 3rd_gear_Ted View Post
Jrz
+1
or
MCS
Bill Verburg
Old 02-22-2025, 08:29 AM
Originally Posted by Bill Verburg View Post
+1
or
MCS
Do you have a link?
Old 02-22-2025, 09:17 AM
wkrtsm's Avatar
You'll need to reinforce the shock towers on the crossmember if you use coilovers in the rear, since there's a history of cracks/tears in the metal on the tower itself and where the crossmember joins the chassis main in the rear engine bay. Going to coilovers involves a torsion bar delete, and the shock towers were not designed to carry the full rear weight of the chassis+engine+transaxle (like the torsion bars were via the spring plates).
Rear coilover choice is a personal preference based on your own due-diligence (research, purchase choice). You have a long wheelbase (LWB) car, and I believe as long as you order coilovers for an early LWB car, you should be good to go. I don't think aluminum vs steel ('69-71) LWB trailing arms matter, since the angle of the shock tower was likely not changed when going from steel LWB arms to aluminum.
Old 02-22-2025, 09:55 AM
Thanks!
I purchased the reinforcement kit from elephant racing that braces the shock tower as well as the area where the 935 spring plates mount. I am planning on doing these mods while the car is in body work. I also have to weld in the rear sway bar mounts to the chassis.
Old 02-22-2025, 10:33 AM
wkrtsm's Avatar
Originally Posted by sebastianroher View Post
Thanks!
Sounds good. I also went with 935 spring plates.
Old 02-22-2025, 11:17 AM
What year is your 911?
Old 02-22-2025, 11:22 AM
