Apologies; Brad Penn vs....
OK, did a search for the oil thread and got through 11 pages and did not find it, so apologies for a separate oil thread. Just want simple answers no editorials.
Been using Brad Penn or Penngrade 20/50 in my 3.2. Suggestion was made to go to LiquiMoly or Motul. In looking at the prices, they both seem to be between 30% and 50% more in price than the Penn. Simple question, is Penngrade that less quality?
'86 944T black/red, chip, fuchs 8's and 9's- Sold '97 Boxster silver/red, big mistake - Sold '99 C2, silver/black, RoW M030 - sold "69 912 white w/ '86 3.2L (like the pic, just not the pic) |
The simplest answer I think, is if you care enough to research oil, then you most likely care enough to change oil regularly. If you are changing oil regularly, then at the end of the day it doesn't matter which brand you go with.
As in many things, the answer is .... it depends.
For what I have been able to find out, part of what make BP Special was the additive package that Lubrizol has discontinued. Many continue to use BP. Some like VR-1. Some like Mobil 1. Some like the Joe Gibbs Products. LiquiMoly and Motul are fine products as well. The issue has to do with excessive flat tappet cam wear in the newer oils with reduced ZDDP. If you change your oil frequently (around 5.000 miles) I suspect any of the 20W-50 formulations of these are ok.
I suspect it makes more of a difference if you are using a conventional vs. synthetic offering from a top manufacturer than which particular synthetic or conventional oil. And there are lots of strong opinions on the use of conventional vs synthetic in an air-cooled 911...so many it is hardly worth discussing. You can find plenty of threads on the topic here and even more on bob is the oil guy. Pick an oil, stick with it (don't change to different oils), change it regularly and you will be fine. |
I used to run Mobile one in everything, years ago Mobile one racing oil stopped putting zinc and additives in the oil. I smoked my aluminum headed motor In my Outlaw super late because of it. Took the motor to the builder he asked what oil I used I said mobile one, he said you must not have got the memo they changed it.
moral of the story Put in something with zinc and change it often if you are racing events. I change the race car oil very couple races regardless of the oil company saying add a court and change the filter. Synthetic with zinc. |
another oil thread ....
Bradd Penn is fine ... no issues..
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Still here
Guess I was bad a math. Seems your find on LiquiMoly works out at a bit over $7 per quart. Thank you
Still here
Incidentally ...
![]() Sigh. |
PCA Member since 1988
I'll note what I've said in several other threads: If you really want to know how well your oil is performing, then you must do oil analysis. Anything else is just guessing.
I use Blackstone Labs. My samples show that oil is good for a lot longer than you think, usually 2x-3x longer. Blackstone also doesn't find much, if any, difference between brands. But don't take my word for it. Instead take a sample and send it to a lab. And go to Blackstone Labs online forums to read more about their testing.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 03-01-2025 at 12:16 AM.. |
there are 2 versions 0w-30 w/ 1750ppm P & 1850 ppm Zn 0w-50 ditto what they lack is the detergent packages that are needed for extended street useage oil change intervals. all that's really needed w/ the cam profiles usually seen in street 9211s is M1 15w-50 w/ 1200ppm P & 1300ppm Zn which does have the extended usage detergent packages If you have more then usually aggressive cam profiles then you might consider something more than 1200/1300
Kind of Blue
I've run 3 or 4 different brands of ZDDP-heavy 20W50 in my 3.2 and now my 2.7. None of my engines have blown up, none burned or leaked oil at a meaningfully different rate, none created a different operating result save for extremely unremarkably small variances in operating temperatures that may have simply been due to ambient weather differences.
I run Valvoline lately simply due to availability and cost.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
Not sure yet. I'm coming up on 5000 miles on this oil change. Previous oil changes were shorter due to me rebuilding the engine a couple years ago. I will be sending in a sample in the next month or so. Then I will decide how much longer to run it. I'm thinking between 10,000 and 15,000. I do about 10,000-12,000 miles in my Ford GT, which I have been sampling for the last 60,000 miles. It also has a dry sump with 9 qts. of oil.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
The motor was an 18 degree 358 cid Chevy motor roller cam, roller rockers, pure race. I still run mobile one in my Benz and the wife's M. Amsoil has impressed me in my dually diesel. Thank for your update Bill, I appreciate it.
After years of purchasing and distributing pallet sized orders of Brad Penn oils, we now have been using Liquimoly 20/50 for about 7 years for our aircooled servicing and engine builds. Very pleased with it. For us, the cost is the same, as we buy bulk 205L drums vs 85 cases of 1qt bottles by the pallet. I am a big fan of Liquimoly products, but also think that the Brad Penn products are great quality. They just became too difficult to deal with logistically- no response to emails and calls, then big increase in shipping costs etc... So we dropped them.
We have an extensive range of LM products in stock, mostly bulk, for all kinds of approval requirements for the vehicles we service. 20 plus different products always in stock. Cheers Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Cheers
FYI, comparing the lubrication needs for a flat tappet motor to a roller tappet motor is comparing apples to nuts.
It is my understanding that research has shown that for a Roller Tappet motor, the level of ZDDP needed to protect the cam lobes does not need to be so high. This was part of the reasoning to lower ZDDP in the newer formulations as all newer cars use roller tappets to improve gas milage.
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 03-02-2025 at 02:23 PM.. |
It's a 2005 Ford GT, and I have 90,000 miles on it. I've been doing oil analysis since 30,000. I'm not the highest mileage out there, though. A friend of mine in Seattle has 150K on his. I want to hit 100K this year. I have to use if for more grocery and coffee runs instead of my F150 or 1973 911.
