VenezianBlau 87's Avatar
First engine/trans drop...pressure plate question
RE: '87 with G50 trans
Nine bolts off of starter ring/pressure plate and nothing will budge. How do you get this d*** thing off?
I read Bentley, Wayne's 101 Projects, and factory manuals.
I quote the factory manual, Repair Group 30-117, Removing (clutch), Section 1. d. : "Remove clutch retaining bolts by slacking bolts uniformly (I did'nt do this). Remove clutch from flywheel."
That's pretty much where I'd like to be right now.
Finding a decent slide hammer to use on the release shaft was a godsend today. Thanks AutoZone for the loaner.
Oh yeah, mine has the original G50 fork/shaft assembly. Bearing surfaces in good shape. I now know what needle bearings are. Guess how many are in each bearing. I think I found them all.
So, how do I get pressure plate off?
Cheers,
Bob Sauerteig
Bob S.
'87 911 ("Hardtop" per neighbor)
Old 07-03-2003, 08:31 PM
I haven't done this with the P car but most other clutch pressure plates are also located inplace by 3 to 4 dowel pins. You simply have to carefully pull or pry the pressure plate back away from the flywheel untill you clear the dowel pins, a gentle pry with a large srcewdriver will help.
Old 07-03-2003, 10:56 PM
andyu911's Avatar
I had the same problem. Like movin said, pry with a large screwdriver gently.
Andy
-'87 Carrera -'73 914 2.0
-'06 Frontier -'02 VW Golf TDI
-'07 GT3 RS -'07 Top Kart KPV-4
Old 07-03-2003, 11:27 PM
Thumbs up
Thanks guys.
I'll go that route. I hope to have some pics to load this weekend.
By the way, there are 23 needle bearings in each shaft bearing. I counted them as I picked them up in the driveway!
Cheers,
Bob Sauerteig
Bob S.
Old 07-04-2003, 07:58 AM
