Any Advantage to Wider Rims?
Let me be more specific. I was looking at the Toyo Website. I really like the t1-S. Anyway I was looking at a set of 245/45s for the rear of the SC. This is the widest 16" tire they sell.
According to the spec section this tire can be mounted on 8 or 9 inch rims. Does the tire sit differently on either rim? Is there an advantage to the wider 9" rim with a tire this size? Thanks Jeff C
Jeff C 76 912E 2.6L |
Chris M 1985 911 Carrera w/ 3.6 |
Check tire rack, they have some 255 x 16
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
Administrator
Yes. A 9-inch rim is a better choice for a 245 tire than an 8-inch rim.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
I have RA1s 245/45/16s on 8s and 9s, visually you can not tell the difference, the only reason for going for a 9 is to get the sidewalls to be more vertical which reduces the roll of the tire, effectively stiffening the side wall.
On the track I do not feel nor see a difference in lap time yet. My skill is not sufficient that it makes a difference. On the car you can not see a difference either, the extra inch in on the inside when it comes to Fuchs. Jim
Jim Hamilton If everything seems under control, your not going fast enough. |
Each tire is designed for a range of rim widths and can work to it's utmost at the larger end of the design rim spectrum.
Thanks Guys!
I already own the 9's, I was just didn't want to know it was all about looks. What's the widest rubber you can/should get under an SC rear arch? JC
The largest I have heard of is an 11.2" secton racing slick.
The largest normaly used(If you can call this normal) is an 11" cross section 275/40
