GTT GTT is online now
SSI installation question - SC 3.0
Backdating the exhaust on my 3.0 and just received a new set of SSI exchangers. The new exchangers have tabs near the rear where I believe earlier cars had studs to keep them from rattling. My 3.0 doesn’t have studs there (circled in red in attached pic). Do I need to drill/tap the block to add a stud here or run them without that attachment? Tried to do a search but wasn’t able to find this particular question addressed anywhere.
‘82 911SC Targa
Mt. Pleasant, SC
Old 04-06-2025, 05:05 AM
buster73's Avatar
On my SC case (1980, 930/09) there were threads in place to fit the early style SSI`s. Probably changed over the years. The additional mounting points sure help to stabilize the whole system but you can probably go without. If you have a chance to drill and cut threads I would do so.
Regards,
Guenter
73.5 911T, mod
Old 04-06-2025, 06:32 AM
Thanks Guenter. Mine is a ‘82. Since I’ve got the motor out I’ll drill and cut threads. I figured it would be better for the extra support but just wanted to check for input before I tighten everything up.
‘82 911SC Targa
Mt. Pleasant, SC
Old 04-06-2025, 09:33 AM
Registered Minimalist
75 911s's Avatar
On my 2.7, one of the tabs fit perfect and I had to modify the other tab to put a step into it to line up with the stud properly. Point is, I don't know that they fit but one engine perfectly and a lot of people don't use the tabs or even have bent them out of the way. The SSI should be rock solid as is, I wouldn't worry about tapping and adding a stud/nut/bolt there.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 04-06-2025, 03:46 PM
A930Rocket's Avatar
I remember when I installed them on my 81 SC, and I drilled and tapped for bolts. Don’t drill too deep!
Old 04-06-2025, 08:37 PM
Thanks all for the input. I went ahead and drilled and tapped for bolts. Maybe it’s not necessary but I like the idea of an extra contact point limiting movement.
‘82 911SC Targa
Mt. Pleasant, SC
Old 04-07-2025, 03:59 AM
