Window frame rivet
Hi guys,
At the moment, I'm restoring the window frames of my 1973 911T. I had to remove all the steel parts prior to anodizing, and now I'm trying to put everything back together again. The main question I have is: what kind of rivet do I need to use to secure the steel bracket to the frame? Can I use a regular aluminum pop rivet, or is there a special rivet I need? Kind regards, D@vid
1973 2.4 MFI bone-stock 911T |
PCA Member since 1988
I don't know for sure what rivets were original, but that looks like steel. I would not use an aluminum pop rivet. I doubt it will be strong enough. How about using a nut and bolt of the correct size?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
'87 Targa
*Warning:* Ignorant thought from 1987 Targa owner!
Would they use the copper rivets from the Targa wing window cap? PN: 900.056.003.20
Thanks guys, I will explore both options. However I don't really know what tools I need for the copper rivets. Also copper may not be strong enough.
Kind regards, David
https://forums.pelicanparts.com/porsche-911-technical-forum/566914-question-asked-but-never-answered-how-do-i-install-new-targa-window-stops.html Mark
1979 911SC Targa |
Thanks Mark,
That might work. Will look into that. Again, thanks for your input guys. Kind regards, David
