Steve Wong/911chips.com
I know this is not new or revolutionary feedback but I like to talk positively about good products/experiences. As we all know performance improvements on air cooled Porsches in not a cheap thing. IMO at $600 this chip is the best value for engine performance (good maintenance aside).
I can’t speak for any model other than the 3.2L 911 because that is what I have. If you don’t have a Steve Wong/911chips.com chip in your car, order one today. I have no affiliation with the company other than I just purchased and installed a chip. Mine was spec’ed for 93 octane w/ a premuffler/sport exhaust. My car is stock other than a premuffler in place of the cat. There are plenty of raving testimonials about this product so this isn’t new feedback, I am just affirming it. This is the most impactful $600 you can spend on your car as far as engine performance. Car runs smoother, better throttle response, better power, pulls through the entire RPM range with more authority and to a higher redline. I have no idea how much more horsepower it added. It is not earth shattering in that regards. Just a lot of small improvements that add up to a very noticeable and positive improvement in performance and driving pleasure. All for a relatively small investment. Get one and enjoy. Best.
Foster Monroe, Ga 1984 911 Carrera Targa |
Porsche Owner
i agree 100%. I waited way too long to pull the trigger and it was so worth it once i finally did. Also, Steve is super great about helping troubleshoot any issues you might have.
FWIW, I feel the same way about the WEVO shifter!
1987 Carrera - 2008 Cayenne Turbo |
The SW chip does indeed improve power delivery and performance across the range, However; as you say; the initial improvement in power is not what its about, its how it affects the drive and feel of the car across the range, had mine in for around 10 years now.
Ant.
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
Thanks Foster
Porsche Owner
It modernized the feel of the shifting. It's more engaging and the throw is shortened by 30%. I did opt for the PSJ as well. It does bring extra noise into the cab (as advertised). but does definitely tighten things up.
Call 911
I certainly agree with flee27. I have both the Steve Wong custom chip and enlarged throttle body on my 3.2L engine, along with some other modifications. Performance, running quality, and throttle response all improved over stock.
Dave Kirk My Porsche restoreth my soul. |
I was unable to identify any improvement with a bored throttle body on my modified 3.2. It felt great but after objective testing I proved once again how unreliable our butt dyno is. I did a post on my findings a few years ago.
Call 911
The 3mm enlarged throttle body was installed along with the custom chip. I noticed a difference in throttle response over the stock throttle body and my previously installed SW chip. But as the two mods were done together, I can't say that the throttle body is the main contributor.
I'm planning to have my car run on a chassis dyno this summer and will report the results along with all engine modifications.
as I understand it, the larger throttle plate in an enlarged throttle body allows more air into the engine at the same part throttle position as a standard-sized throttle body. This provides the "butt dyno" perception of increased (part throttle) performance/different throttle response. However, since the throttle body's diameter is not a significant pinch point in a stock or mildly tweaked 3.2 Carrera engine, full throttle performance (as tested on a dyno) is not materially affected.
Call 911
Darrin, I totally agree. And if there was a power gain to be had, it would be slight and only at the top end of the RPM range of the engine.
The idea is totally laughable, when one considers ALL the key variables for intake air volume. Consumer naivety always results is wasted money! Found this Pelican Parts thread; Performance Tuning - The Myth -
Dave Last edited by mysocal911; 04-04-2025 at 09:11 AM.. |
Hi Loren,
I wondered when you might show up ![]() I do agree on the throttle body conundrum though, unless your doing serious increases elsewhere, its pretty pointless, and can in some cases cause adverse effects. Ant. Quote:
dkirk - please keep us informed on your custom wong / chassis dyno activities.
This is on my 'to do' list. I have run an SW chip for 10 years along with other mods but want to dial it all in on a dyno. Regards, Steve Quote:
Oh, so you're going to "performance tune" your 911 3.2, right? What "tuning-app" will you be using?
Dave |
Dave,
SW chips can 'flash' a chip specific to your (my) 3.2 based on actual dyno run A/F data. So although my chip seems to be fine 'as is' based on all of Steve's experience, I thought why not send him data from a few dyno runs and have the chip flashed to my car. I'm open to hearing why this is a good, bad or marginal idea. The obvious answer is that this is silly because he's likely 99% there already based on how much data he has accumulated over the years. The argument against that may be that why not get to 99.5%. Regards, Steve |
Here we go again....
May as well start an oil and filter thread while you're at it. |
Linking to a thirteen year old closed thread that had devolved into hot garbage. Gee "Dave," that must have been really difficult to find. ![]()
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
I have a few decades worth of real world experience with off the shelf 3.2 chips (SW, Weltmeister, Superchips, Autothority, Sal Carceller, etc) in MANY different 3.2s. I've tried / run different MAF conversions too. The shop I worked at installed many Weltmeister 3.2 chips in-period. I've had numerous cars tuned on the dyno, including a pair of 3.2s. Steve Wong dyno tuned my former '88 3.2 and one of my current '87s, a 3.4, with his throttle body. Send me your number via DM if you'd like to discuss the particulars. Happy to discuss the objective and subjective, real-world, pros / cons / good / bad / marginal of all the above.
Thank you Frank - I have enjoyed seeing your car on several occasions during the Monterey Auto week and I have a file of pictures for reference.
I do want to memorialize my mods and the proven BHP for 'Dave' - keep in mind my 3.2 has never been opened, good compression tests and 132,000 mi, your results may vary. I exclusively use Chinese oil filters and Venezuelan oil. Decat pipe 21 bhp Stock exh cut open, cut up, welded back up 8 bhp Cup air box 18 bhp Enlarged TB 15 bhp Extrude Hone intake 2.9 bhp Clean air filter 7.1 bhp SW Chip +/- 69 total Round off or up with over rev 77 BHP Last edited by stephen1070; 04-08-2025 at 06:57 AM.. Reason: updated with even more power ! |
