915 shift linkage
newly acquired 86 coupe. The 915 shifting is messy.
This is what my existing shift linkage looks like, ![]() Is this original? Would the Rauch & Spiegel Manual Trans Shift Shaft Coupling | 91142402404 be an upgrade? |
Not original. Known as a "helicopter joint" style coupler. Is an upgrade over stock and rarely fail.
-Tony Instagram: @Pablo_the_Porsche | @RuchlosRallye AchtungKraft #002 |
PCA Member since 1988
Unless it's loose, keep it. Look at the plastic bushing in the tunnel ahead of the parking brake, and the plastic cup at the bottom of the shifter. Lift up the shifter to see the cup.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Been here a while
what PeteKz said, if you are sloppy with that coupler in the rear, pull up the shifter and replace the 2 bushings.
looking for 1972 911t motor XR584, S/N 6121622 |
winter
I just installed a Karsten Spring (available from Stella’s)
https://forums.pelicanparts.com/porsche-911-technical-forum/1053247-915-stock-shifter-improvement-spring.html And an ultimate sift rod bushing (available from 914-6werkshop.com) https://forums.pelicanparts.com/porsche-911-technical-forum/1117369-ultimate-shift-rod-bushing.html And I’m pretty pleased with how my 915 functions with those two inexpensive and easy modifications. You might want to try them as well as replacing the other bushings as mentioned above since you already have the helicopter upgrade.
Tom '76 Targa |
It's messy because you are missing the rubber boot. Clean that area up, buy the boot, then.......
https://www.*******.com/blog/how-to-replace-the-shift-coupler-boots-on-a-classic-air-cooled-porsche-911 Replace asterisks with... f c p e u r o. So frickn stupid they block urls' like this.
72 911 Although it is done at the moment, it will never be finished. Last edited by tobluforu; 07-03-2025 at 02:00 AM.. |
They block the urls because it’s a competitor.
The forums don’t operate for free. |
That appears to be a WEVO PSJ coupler.
I have used on since about 2007. No alternative would offer any better performance. The stock rubber boot does not have anything to do with performance, but it can help keep the area tidier. The 915 system includes two different bushings up front... one for the bottom of the shift lever and one for a bracket attached to the base of the shifter. The stock ones work fine but can wear out quickly. Improvements can often be achieved by making sure all bushings are in good shape, and proper adjustments are made. Further improvements can be achieved via one of many aftermarket shifters. I have used the WEVO shifter since 2006. I have many friends with street and race cars that have enjoyed the benefits of the WEVO shifter for 20+years. I also use the WEVO clamp back there-- a bit more robust and "positive" than the stamped steel factory part. The WEVO products were designed and commercialized by the late Hayden Burvill. RIP. Great person and great racing professional, fan and Porschephile. He helped me many times and in many ways. Hayden was the chief steward for the first year or so of the Porsche Racing Club, and did a great job. Once while at the track: He adjusted my shift mechanism... I learned a few tricks from him which I still appreciate. He found some cracks in my wing uprights that could have lead to catastrophic failure. I was able to address them with materials on hand and did not miss a session oro race. RIP. ![]()
Mike PCA Golden Gate Region Porsche Racing Club #4 BMWCCA NASA Last edited by Mahler9th; 07-03-2025 at 10:38 AM.. |
Still here
For one, NVH isn't an issue in the latter. Regular rebuilding of the drivetrain is par for the course as well. |
For what it's worth, no Porsche aftermarket parts businesses are making their own helicopter joints. They're specing them from an aerospace manufacturer and private labeling them. It really doesn't matter who you buy from (WEVO, Stomski, etc)
Yes get the JPNovak aftermarket bushing, nice product and the spring as well.
You may as well change out the 3 throttle rod bushing in tunnel too, take a look at pedal cluster bell crank bushings as well, if plastic - change them. All cheap parts and easy fixes. All these 40-50 yr old original plastic ones that are yellowed are likely already cracked or crumbled away. Also - Get the shift rod boots, inner and outer and replace the leaky shift rod seal. Not only do these boots keep trans oil from leaking into the tunnel, they keep dirt the off the shift rod. Any clinging grit on the shift rod prematurely wears out the $10 seal every gear shift. The slow leaking trans oil seeps into the boots and not on floor. Trans oil smells up tunnel too. The rod seal is a job I’m dreading to DYI. Oh, AND - The boots keep mice out too ! Pelican sells all the above mentioned that you need. Make It One Big Beautiful Order ! |
greg79s
I strongly recommend the stock original shifter system. The 915 gearbox shifts very smooth with the original shifter. The original owner of my 1985 Carrera installed a Porsche short shifter early in ownership and was hard on the transmission over time. The stock shifter was reinstalled and improved shifting.
I believe I found my issue with shifting. 2nd and 4th gears became impossible to shift into.
![]() ![]() The shifter ball was just moving around ![]() And then I found the linkage Shaft at the cup loose and cracked under the (non-oem) hose clamp. ![]() ![]() ![]() ![]() ![]() I guess it could be welded but I'm going to opt for a used shift rod. Now the fun part of trying to replace it. I assume the Trans needs to moved and this pulled from the small tunnel? Already ordered the aftermarket bushing for the Rod. Any one try the Jwest shift rod bushing CUP? While I'm in there... ![]() Last edited by Brickwhite; Yesterday at 05:47 AM.. |
Yikes!
Jwest makes quality items, I wouldn't hesitate to buy his products. Shift rod: On a 901, raise tranny and engine, on 915, drop it.
72 911 Although it is done at the moment, it will never be finished. |
The stock shift cup can be easily welded in place. Mine was beginning to become loose (not uncommon) and a few spots with a MIG welder took care of that. Disconnecting the rod at the back allows for rotation of the shaft to ensure adequate number of welds on the circumference. If you go that route, disconnect the battery and have the ground clamp close as possible to the work.
1986 Targa Guards Red 2021 MT09 SP |
