Nuts: Are these "one-time use"?
Getting ready to order some parts and can't recall where I read this but... are these "one-time use" nuts on '87 Carrera:
1. Trailing Arm nuts (near trans tunnel)?
2. CV Axle nuts (32mm, outboard CV, not castle nut)?
Thanks in Advance!
Old 04-03-2025, 03:05 PM
Driver
Noah930's Avatar
I have been told the CV joint/axle bolts are to be replaced after each use.
1990 Black 964 C2 Targa
Old 04-03-2025, 05:00 PM
A930Rocket's Avatar
On my 81SC and 87 930, I reused the CV bolts all the time. As long as the heads were screwed up. YMMV.
Old 04-03-2025, 06:53 PM
CV nuts? Do you mean bolts? I would not reuse them. They’re cheap, why risk it? Not sure of the size for your car, but on a ‘77 they are 45 mm.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 04-03-2025, 07:20 PM
I'm talking nuts (not bolts). Specifically the 32mm axle nut (at the end of the outboard CV axle) AND the nuts at the trailing arm bushing (near the trans tunnel).
Old 04-03-2025, 08:39 PM
Big 32mm central nut is reusable. Torque it to spec.
Gilles
RoW 88 Carrera coupé
Old 04-04-2025, 01:50 AM
Shaun @ Tru6's Avatar
stub axle nut is reusable, if you wanted to allay any fears, put a dot of loctite blue on the threads.
Tru6 Restoration & Design
Old 04-04-2025, 03:04 AM
On my 81SC and 87 930, I reused the CV bolts all the time. As long as the heads were not screwed up. YMMV.
I agree, as long as the heads and threads are completely undamaged there is no need to replace them.
If you have the Schnorr serrated washers, they can also be re-used if undamaged. However they can only be used a few times before they have damage and need to be replaced.
Old 04-04-2025, 09:41 AM
Trailing Arms Nuts Re-usable? (not bolts)
Anybody know if the trailing arm nuts (22mm socket, near the trans tunnel) are one-time use? They appear to be the "self-locking" type.
Old 04-08-2025, 09:32 PM
Those are reusable
Old 04-09-2025, 03:05 AM
Originally Posted by Shaun @ Tru6 View Post
Those are reusable
And a pain in the ass to access
Old 04-09-2025, 08:03 AM
