Time for a beer.
Gilles RoW 88 Carrera coupé |
Indeed!
![]() Thanks again to both you and Spuggy for your help on this one ![]() Ant.
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
Heh. I was going to say "it's 5:00 PM somewhere" - but given the time zone you're both in, it's even appropriate/socially acceptable
![]() you got it working Ant!
'77 S with '78 930 power and a few other things. |
But if one side/terminal were fixed in the package, then it could matter a lot - any magnet action would be moving the mobile side further away from the fixed terminal if it was inverted... Fingers crossed it's that easy!
You have to swipe the magnet close to the rear of the sensor while watching your ohm meter response, its a bit fiddly to get the right orientation of the magnet, but if the sensor is ok, you will get the switch to make or break with a good strong magnet.
Ant. Quote:
UPDATE. Bought a second sensor. Tested on bench with positive results. Installed and it works!!! Bad new sensor. Thank you all for the feedback and the help. Side note helps to have a lift as the swap becomes a 10 minute job !!!
Wow, that seems unlucky... Glad you got it sorted!
![]() Good to hear you got it sorted! Ant.
