Time for a beer.
Gilles
RoW 88 Carrera coupé
Old 05-15-2025, 08:53 AM
Originally Posted by wazzz View Post
Time for a beer.
Indeed!
Thanks again to both you and Spuggy for your help on this one
Ant.
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 05-15-2025, 09:41 AM
Time for a beer.
Heh. I was going to say "it's 5:00 PM somewhere" - but given the time zone you're both in, it's even appropriate/socially acceptable
you got it working Ant!
'77 S with '78 930 power and a few other things.
Old 05-15-2025, 09:53 AM
Originally Posted by spuggy View Post
heh. I was going to say "it's 5:00 pm somewhere" - but given the time zone you're both in, it's even appropriate/socially acceptable :d
You got it working ant!
Old 05-15-2025, 09:54 AM
Originally Posted by Sliver911 View Post
TIn searching further I realized that I installed the sensor backwards. Initially I put it in with the tabs facing in toward the transmission when on fact they should be facing outward. Will get car back on the lift this week and flip it. I’ll report back with the results.
Huh, never thought about that. Many reed switches aren't sensitive as to orientation.
But if one side/terminal were fixed in the package, then it could matter a lot - any magnet action would be moving the mobile side further away from the fixed terminal if it was inverted...
Fingers crossed it's that easy!
Old 05-15-2025, 10:03 AM
Thanks for the replies all. In searching further I realized that I installed the sensor backwards. Initially I put it in with the tabs facing in toward the transmission when on fact they should be facing outward. Will get car back on the lift this week and flip it. I’ll report back with the results.
Installed new sensor correctly and no-go. Cannot seem to get any ohm readings while either out and running a magnet or installed and wheels turning. I used a metal pickup wand magnet and it does not register. Going to with ordering another sensor with the assumption it is bad (it’s a Uro) and on from. There
Old 05-16-2025, 12:26 PM
You have to swipe the magnet close to the rear of the sensor while watching your ohm meter response, its a bit fiddly to get the right orientation of the magnet, but if the sensor is ok, you will get the switch to make or break with a good strong magnet.
Ant.
Nikola Tesla
Old 05-17-2025, 03:39 AM
UPDATE. Bought a second sensor. Tested on bench with positive results. Installed and it works!!! Bad new sensor. Thank you all for the feedback and the help. Side note helps to have a lift as the swap becomes a 10 minute job !!!
Old 05-25-2025, 02:24 PM
Bad new sensor.
Wow, that seems unlucky... Glad you got it sorted!
Old 05-25-2025, 04:23 PM
Good to hear you got it sorted!
Ant.
Nikola Tesla
Old 05-25-2025, 11:16 PM
