911 3.2 head temp sensor pin location
I removed tech connector for the head temp sensor as it needed to be replaced and forgot to note the pin location. Does anybody know if ground is the top or bottom pin?
Old 05-17-2025, 02:42 PM
The old one grounded through the sensor to the head. The two wire sensors don't, so it shouldn't matter.
206 637 4071
Old 05-17-2025, 07:21 PM
Mine is a 2 pin connector. One being ground the other I assume is signal. Are you saying it doesn’t matter what pin goes to what?
Old 05-18-2025, 11:28 AM
Its a NTC, a kind of resistor. It has no polarity so it doesn't matter which way it is connected.
Gilles
RoW 88 Carrera coupé
Old 05-18-2025, 11:35 AM
Pretty much like a light bulb. Works regardless of polarity.
206 637 4071
Old 05-18-2025, 01:30 PM
