Jack
915 Rebuild Kit
All
I did some searching, didn't see anything definitive.
Is there a master thread on a 915 rebuild kit? Is there a base kit out there including syncros??
My 85 915 is starting to give up the ghost in 2nd syncho, and I am not much of a double clutcher.
As always, much appreciated.
Jack
85 Carrera Cab
Old 05-25-2025, 11:00 AM
You tear it down and order the stuff it needs, basically. You could start with 5 syncros, 1/2 shift sleeve, 3/4 shift sleeve, maybe 2nd syncro teeth and a gasket set to get you going.
206 637 4071
Old 05-25-2025, 11:28 AM
Jack
Thanks for the reply, as always, Pelican forums are the best.
Assume the sponsor has most of the parts? Or should I hunt around?
85 Carrera Cab
Old 05-25-2025, 12:26 PM
A930Rocket's Avatar
While PP probably has all the parts, I would shop around. Last time I checked Stoddard had all the parts at a good price.
I’ll be rebuilding my 915 at some point.
Old 05-25-2025, 04:12 PM
Jack
10-4...will start checking. Thanks all
85 Carrera Cab
Old 05-25-2025, 07:50 PM
California Motor Sports uses OEM bearings and syncro rings only.
I had them assemble my 915. A whole story by itself.
Old 05-26-2025, 05:51 PM
shoooo32's Avatar
There's a ton of 915 threads if you're willing to do a little hunting. It's worth your time to spend an afternoon digging. I reference Pete Zimmerman's wiki at least once on each box I do.
One major item of note: only Rauch & Spiegel gear teeth have the required back taper. OEM, factory, etc. do not. Beyond that, don't reinvent the wheel. Parts are expensive but there's really no way around that. Buy OEM and sleep good at night.
-Tony
Instagram: @Pablo_the_Porsche | @RuchlosRallye
AchtungKraft #002
Old 05-27-2025, 04:57 AM
Check various Porsche dealers online too, like Gaudin, Suncoast, and Sunset. You might be surprised at their prices...in a good way.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 05-27-2025, 12:40 PM
PCA Member since 1988
I'm almost never surprised by Porsche prices "in a good way"!
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 05-28-2025, 08:50 AM
Full Send Society
RM European too…
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 05-28-2025, 08:52 AM
Albins do too...
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
