LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
911SC Tinkerer
merlinfe's Avatar
Post your ITB Setup
Hey PeliCANS,
I've been researching ITB set ups for a while on the forums, and while there are GREAT threads here, I noticed there was no single collective thread on everyones set ups. I'd like to get a general idea of what you've done to set it up, so I'll list a few things pertinent to a proper set up and we can go from there. Feel free to add extra info and of course PICTURES! This will be aimed at more of the DIY crowd than people who have systems for sale, but post what you got anyhow.
ITB source: (for example GSXR-600 TB, home-brew, Jenvey, etc.)
ECU : (Megasquirt Version 67, etc.)
Injectors Used: ( Manufacture, flow rate)
Manifold source: ( Stock weber, zenith, home-brew, etc)
Fuel Pump:
Pressure Regulator:
Ignition / Crank trigger:
Rough total cost for a running set up:
Any info you gained that wasn't on the forum.
Thanks Pelicans, hope to see some awesomeness.
- Steve
-'83 911SC Coupe
SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc
Old 08-17-2016, 01:29 PM
Cars Ruined My Life
impactbumper's Avatar
sub'ed, i am working on this as well.
Old 08-17-2016, 02:03 PM
Chain fence eating turbo
I compiled parts for GSXR 1300's ITB's, and I'd say I'm $600-800 in.
Already have MegaSquirt II v3.57, twin 044 pumps, stock 3.2 FPR, 80lb Deka injectors, GSF crank trigger system with 36-1 trigger wheel, VR mount, and dizzy block off.
I'm turbo, so I have to build logs atop and appropriate piping from IC.
Old 08-17-2016, 03:36 PM
Is there a link to some of these set ups? Thx
Old 08-21-2016, 05:24 PM
Turbonut
Raceboy's Avatar
GSXR-1000 ITB's, VEMS ECU. Have made several sets for 993, 911 3.2, 2.7.
Last iteration is for my 2.4 S with E46 M3 electronic actuator and E46 electronic pedal (to get rid of the long throttle cable). Tested fine on the bench.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 08-21-2016, 08:47 PM
al lkosmal's Avatar
ITBs
X-Faktory - Home
https://www.youtube.com/channel/UCA2Ea55IQplBIL2F025_P9g
https://www.youtube.com/watch?v=enRgZ4FUNB4&feature=youtu.be
my ITB setup(s)
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 08-21-2016, 08:55 PM
I started buying all the bits and 3D modeled my own system, but opted to go carbs. In the end, I felt that the cost was too close to carbs and that my home brew EFI will have no value to others in the end.
Home-brew ITB setup
Triumph 900 ITB's $50
Tubing 100
Flanges 50
Bungs 50
boots 50
venturi 200
ECU 1375
Injectors 250
Fuel pump 150
Regulator 150
Hardware / lines 100
Welding / fab 250
Filter assys 130
Eids 200
Tuning time 0
Crank trigger 300
Throttle linkage 100
Wide band o2 200
Total $3,705
Jenvey ITB with PE-LTD ECU
ITB 3200
Ford EIDS 125
Injectors 200
TPS 100
ECU 1375
Wideband 300
Wires 300
Harness 143
Crank Trigger 300
Total $6,043
Vems with Borla
TWM / Borla ITB 2300
Vems 1535.91
COP 460
TPS 100
Crank trigger 220
Pickup sensor 50
Injectors 250
Total $4,915
PMO / Dist
Carbs 4100
Dist 1300
wires 300
6-AL2 CDI ignition 500
Coils 90
Total est $6,290
Old 08-22-2016, 03:57 AM
Here's my twist on an ITB setup from TurboKraft, powered by Rasant Products AEM Infinity ECU kit:
Marc Zurlinden
zurlindengruppe.com
Old 08-22-2016, 05:35 AM
Shaun @ Tru6's Avatar
Beautiful Marc!
What green is that? it's strikingly similar to the Velvet Green on my 69.
Tru6 Restoration & Design
Old 08-22-2016, 06:22 AM
Mike Billings's Avatar
Built on 911E throttles enlarged to 40mm by Eurometrix, 39mm ports. Bells are for 44mm Weber (VW). Stacks are 1/2 thick wall, then tapered to fit.
07 911 Turbo - Pilot Sport Cup 2 ZP
96 Carrera 4 - Toyo R888r
73 911E - Hoosier R7 + twin 75's
92 Corvette - Nitto NT01
14 BMW X3 - Pilot Sport A/S 4
Old 08-22-2016, 06:31 AM
9elf's Avatar
Mine. Nearly ready.
https://www.youtube.com/watch?v=KiUwtRVHZjw
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan.
“Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan.
Old 08-22-2016, 07:14 AM
al lkosmal's Avatar
Mike....I put together a similar configuration a couple of years ago....worked great.
https://www.youtube.com/watch?v=SpPM1SZL_rc
regards,
al
RGruppe #669
Old 08-22-2016, 07:18 AM
Originally Posted by Shaun @ Tru6 View Post
Beautiful Marc!
That's a 356 color "Smyrna Green"
It photographs nicely but the pics just don't do it justice! Wonderful depth and tone.
Old 08-22-2016, 07:43 AM
Registered 911 User
Matt_911's Avatar
Here's mine – I'll have to check the details if anyone is interested, but basically it's a Haltech running ITBs with twin plug heads.
http://i.imgur.com/k7Vcxhcg.jpg
Matt Wilson
Founder / Creative / Art Director
www.theotherdimension.com
Old 08-23-2016, 02:38 AM
al lkosmal's Avatar
3.0
Here's a 3.0 I built a few months back.
JE 9.5:1
E-ish cams
x-faktory S3-EFI/ITBs
Rasant engine management
COPs
headers
sport muffler
And a 2.7S recently shipped.....
JE 9.5:1
TWM/Borla 40mm ITBs
Early E-cams
MS3X
Crankfire/EDIS
Early headers/heat exchangers
sport muffler
Al Kosmal
the x-faktory
koz@x-faktory.com
RGruppe #669
www.x-faktory.com
RGruppe #669
Old 08-23-2016, 06:49 AM
al lkosmal's Avatar
I have another 3.0 and a 2.7 headed my way.........both of them will be rebuilt and turned into EFI/ITB hipo engines.
regards,
al
RGruppe #669
Old 08-23-2016, 11:16 AM
Here's the Rasant Engine Management kit installed on PMO 46mm ITB's
1975 911S - Twin-plugged 3.5L
www.rasantproducts.com
Old 08-23-2016, 01:19 PM
what Cerakote color was the fan and housing painted?
Old 08-23-2016, 01:27 PM
It's a ceramic coating. I can't recall what color, it looks like a protective coating with the natural finish. There's a guy here in So Cal that does it.
Old 08-23-2016, 01:37 PM
Thanks, I do fan restorations as well and use Cerakote.
I'm picking up a 2.7 RS longblock this weekend and will need Webers or an EFI/ITB system for it.
Old 08-23-2016, 01:38 PM
