Is this a bit Hot
What do people see on there temp gauge? Do you think this is a bit hot?
82’ SC Targa.. Been driving for 30 minutes, steady at this temperature..
Not hot for me but that also depends on ambient temp and how hard you run the engine. If it is steady, your outside thermostat is opening and regulating, so this is good.
Gilles RoW 88 Carrera coupé |
This is a good reference pic. Thanks to whoever originally posted it.
John
![]() 30 years ago, when I bought my 85 911, I hated the vague no numbers temp gauge. I bought a new sender, and gauge insert. It was super easy to put in a numbered temp gauge. Then just a year or two later, my tach was bouncing around. That is almost always from the alternator overcharging. I put in a volt meter under the tach, and it got rid of that stupid shift light. I have driven for hours in 105+ degree temps, and the AC blowing cold. I had to install a fan on my front oil cooler. The fan simply works. And contrary to popular belief, even on the highway at 75 MPH, the fan helps. I tested that on August driving back from Savannah, GA in 100+ degree heat. Since my 85 had a front cooler, but no factory fan, I had to add the fan. I was unwilling to buy a new oil cooler with the bung for the electric switch. My fan has a total human interface, a toggle switch I flip on once the temps get to 210, and back off once it is below 210.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Still here
In traffic, on the freeway, "mountain" roads ? It depends. At a constant 65 mph on a pleasant day, that's too high. |
PCA Member since 1988
Best oil temps are between 212F/100C and 230F/110C-ish. Why? Above boiling temperature drives moisture out of the oil much faster than temps below boiling, and moisture is the internal enemy of an engine, especially one that does not get driven often. 230/110 is comfortably below the oxidation point of even cheap dinosaur oils.
Contrary to some popular opinion, cold oil is not good for an engine. In fact, many of our cars run oil temps too low during cool or cold days.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 06-07-2025 at 01:28 PM.. |
I run VR-1 20/50. Erik
1986 911 Coupe 1986 911 Targa Last edited by fallingat120mph; 06-07-2025 at 02:04 PM.. |
Got to drive them and ride them ![]() Erik
1986 911 Coupe 1986 911 Targa |
1988 Carrera
If you look under the lip of the gage, where the needle is pointing you will see the temp in C. You have got to get your head around the steering wheel.
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
At least the heater still works great in those temps!
You may see the calibration numbers if you look at the gauge face kinda hidden towards the bezel.
I have a 80 sc and even with 30* Celsius weather, mine doesn't go that high after 30 min drive. Could be stop and go? Somebody mentioned blower fan kicking in once high temp reaches.. are you talking about alt fan or you have another blower in the engine comp? Just curious.
Kind of Blue
On a summer day or during spirited driving, I wouldn't think twice about that temperature.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
Still here
Drove the SC on a nice 70F day, temp gauge pegged at the first white bar even after 15 minutes of idling while I measured the temps using the IR gun, oil filter at 200-210F ... exhaust ports around 450-500F give or take a bunch, hard to get a good bead on those.
On the 930, the mark circled in red is 212*. Probably the same for others.
Cruising along at the highway at 3,000rpm that would strike me as warm. Spirited driving at lower speeds that would be expected.
1982 911SC |
So, yesterday with the temperature at 90 degrees (32C ?) and humidity around 60-70% (dew point 68-74 per app) averaging 75-85 miles per hour (may have been higher???), for nearly an hour, here in the Midwest, this was my reading -I may have been in fourth as I was getting ready to exit the interstate:
This engine has 200,000 miles on it with a broken headstud, and some seepage near the front oil cooler in the lines. AC has been removed (so, no AC running) and I use Valvoline 20/50 oil... Anyway, just contributing... Erik
1986 911 Coupe 1986 911 Targa Last edited by fallingat120mph; 06-27-2025 at 11:45 AM.. |
