Air Cooled
'78 SC Elephant Racing Suspension Rebuild
Hi folks, I am currently walking down the suspension upgrade path that many of you have done before (and thank you for posting your builds!).
Here's what I have from ER: - ER 30mm raised spindles - Bilstein struts (custom valved) with welded gussets - Racing bump steer kit with rubber boots, weld-on steering knuckle brace - 21/28 hollow torsion bars - ER Poly Bronze rear spring plate bushings - ER Rubber bushings front A arms - Ball joints - ER Mono-ball upper strut mounts - ER Low-friction control arm mounts - ER Quick-change adjustable spring plates Other New Parts: - Rebuilt Carrera front calipers (kits from our host) - PMB fully restored/rebuilt/replated SC Rear calipers - Stainless Steel brake lines (fr/rr) (from our host) - New Carrera front rotors (from our host) - New SC rear rotors (from our host) - New rear bearings (from our host) - Pedal bronze bushing rebuild kit (from our host) - VW Rubber upper strut covers (Thanks for that tip Trog!) - Brand new drive axles with CV joints (from our host) - New semi-metallic brake pads with new caliper clips (from our host) What I'm reusing: - Rear Bilstein Sports (less than 4k miles) - Later Carrera sways fr/rr - Tarrett rear sway bar links - ER strut brace I've started working on this last week and have removed the front suspension and brakes. Today I'll start to disassemble the control arms and clean up the camber plates. It's as cold as a meat locker in the garage, so I may head out and pick up a propane garage heater. Here are some pics of the work so far. Pelicans have been very helpful and I've saved a lot of time by learning from others. ...and by using a heat gun, penetrating oil and an air gun to remove everything. Thanks also to Chuck at ER who's been very helpful, assisting me to put together a great mountain/canyon carving set up! More updates as I work through the front end, then it'll be on to the rear end, then the brakes. Cheers, - Craig_D ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 Last edited by Craig_D; 03-19-2013 at 02:51 PM.. |
Air Cooled
Pics
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
Air Cooled
More Pics:
nice work, can I send my car out to you? ;-)
Sold: 1989 3.2 coupe, 112k miles |
I'm about to tackle the same job...
'67 911S '69 911S, '70 911ST '73 911T Targa Signal Yellow '78 911SC backdate |
Air Cooled
I talked to Chuck about it, and with the Carrera sways fr/rr, this would be a well balanced system. If I did the through the body front sway, I'd have to do a new rear sway also, and then we're talking about some pretty good extra coin. If I do go with the through-body sway, it wouldn't be too hard to do later.
Gary R. |
Formerly known as Syzygy
Nice project. I helped a friend do the same thing last winter. Lots of fun. I really like the idea of using the roasting tins for the parts and/or catching brake fluid drips. Good idea...
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
PhD on Pending Projects
Subscribed!!
Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet |
Beautiful! Planning to do the alignment work yourself?
Hey just was reading your build posts any time you need help working on your porsche let me know I am hoping to one day buy a 911 of my own and any education would help ! I live in Arvada so I am quite close . Looks Great . Patrick
Air Cooled
I'll do some basic alignement myself, just enough to get me to the shop that will corner balance and align her.
I had to warm up the CB750 and bring her back into the garage to help warm it up! Pretty damn cold out there! haha Ok, back to stripping the control arms..
ditto... will be watching this post...
btw, I used to have a '76 Super Sport 400-four, the little brother to that big 750.
jt '83 SC '96 M3 6 Bicycles 2 Sailboats Last edited by Kraftwerk; 12-31-2012 at 09:52 AM.. |
Tired Member
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
Air Cooled
Spaced out...?
Questions for those in the know...so one Boge strut's spindle had a spacer on it (which was a pain to get off) and the other side DIDN'T!
![]() ![]() In looking at the Bentley book, I see TWO spacers on the spindle. ![]() The question is: is the Bentley diagram just showing the ONE spacer (per side), twice (Once on the spindle and once exploded). So, there's supposed to be ONE spacer per side, correct? Why the hell did the other side NOT have a spacer...?? ![]() ![]() ![]() If my thinking is correct, I have to order TWO of these spacers.
French Import
Craig, it seems you used your impact gun quite a bit. What is the capacity of your compressor? Thx!
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Tired Member
Could the missing spacer be stuck to the old inner bearing?
French Import
The Boge strut changed in '86. The biggest concern is usually getting the correct insert, as the design changed. I wonder if the spindle also changed and, if it did, you had a previous owner who replaced one of the struts at some point. Regardless, this should not be a big issue since you have shiny new struts. I replaced my Boge's with raised Bilsteins similar to yours and never had to deal with any spacers; just the normal bearing setup.
Edit: just looked at the pics of your struts and noticed that the spacer isn't there on your new struts. Oops! Last edited by JP911; 12-31-2012 at 10:46 AM.. |
Air Cooled
![]() ![]() For the spindle spacer; I've tested it's placement in the bearing seal and it seems that there should be ONE per spindle, as far as I can tell. I've ordered a set from our host, along with all new front inner and outer bearings. I'm guessing that at least the side without the spacer is worn strangely, and this isn't where I want to save some dollars. ![]()
