LinkBack Thread Tools Rating: Thread Rating: 14 votes, 4.36 average.
Air Cooled
Craig_D's Avatar
Originally Posted by JP911 View Post
The Boge strut changed in '86. The biggest concern is usually getting the correct insert, as the design changed. I wonder if the spindle also changed and, if it did, you had a previous owner who replaced one of the struts at some point. Regardless, this should not be a big issue since you have shiny new struts. I replaced my Boge's with raised Bilsteins similar to yours and never had to deal with any spacers; just the normal bearing setup.
Edit: just looked at the pics of your struts and noticed that the spacer isn't there on your new struts. Oops!
Haha right! I'm missing a spacer, so I ordered a pair of fresh ones. The PO did mention to me that he replaced a strut, but like you said, I've got a new pair of Bilsteins, so I'll be good to go with a set of spacers. It won't slow down the project...plenty to do (including rebuilding four calipers and doing the entire rear end of the car.. Oh yeah, and I already have rear bearings, so that job will take some time too.
And hey, it's after 12 here...I can have a beer while I work (it will stay nice and cool in the garage
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 12-31-2012, 10:50 AM
Air Cooled
Craig_D's Avatar
Here's the difference between the hub/bearings that had the spacer, and the one without. I'm replacing all of it..
'69 Honda CL350
Old 12-31-2012, 11:37 AM
break fix drive repeat
rwilner's Avatar
I just finished this project over the weekend, on my 84. It took me close to 2 months to complete the project only because I was waiting for parts to get powder coated and life gets in the way...
I had an almost identical list of parts, except I also did the trailing arm bushings and rear wheel bearings. My TA bushings were really ok, so if you're considering replacing those, I'd say evaluate them first because it's a PITA. I might also suggest you replace your tie rods with turbo tie rods "while you're in there"...it will add maybe 2 hours to the whole job.
Your work area looks very clean and organized. If you have kids, I hope they're paying attention!
Rich
Rich Wilner =======================
Fun: 84 Carrera slate blue metallic
Sold (and Missed):73 914 2.0L signal orange
Old 12-31-2012, 01:39 PM
Other one I would do is the steering rack bearing replacement. Not many dollars, but makes a huge difference, and is good for a long time.
SC Steering Rack DIY Bearing Replace
Kinsley
1980 SC Targa - MS2, EDIS
Old 12-31-2012, 02:33 PM
Air Cooled
Craig_D's Avatar
Rich
Hey Rich, thanks, it's pretty organized, but more needs to occur. I do have Turbo tie rods in there, so I'm good to go on that front. I also do have the rear bearings and the banana arm bushings. I plan to do all of them, but I'll take a good look before I plunge in.
'69 Honda CL350
Old 12-31-2012, 04:03 PM
Air Cooled
Craig_D's Avatar
Not a bad idea. Did yours show signs of needing new bearings? I've done the upper steering rack bushing and since that, the steering has felt great.
'69 Honda CL350
Old 12-31-2012, 04:05 PM
Tired Member
DaddyGlenn's Avatar
the bearings in my '78 were toast. cheap and easy rebuild...
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 12-31-2012, 04:14 PM
Air Cooled
Craig_D's Avatar
Well this afternoon, I removed one torsion bar from the left control arm. It was stuck on the end cap pretty damn well.
Then I moved on to the rubber bushing removal. A few things that I've learned here; 1. my micro bench vise it too freakin small!! and, 2. use a lot of heat to cook that rubber bushing. It smelled like a dumpster fire in my garage until I opened the door...then it was cold. I guess I learned another thing...being cold sucks. I went to Home Depot and picked up a propane radar dish style heater. I'll be using that starting tomorrow.
The torsion bar had some rust and possible wear. The rubber bushing had the typical deformation. Glad to be moving forward.
Some more pics of today's progress:
'69 Honda CL350
Old 12-31-2012, 04:16 PM
Elombard's Avatar
Why did you decide to go with rubber replacement instead of poly bronze or the new sphericals?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 12-31-2012, 04:18 PM
Air Cooled
Craig_D's Avatar
I decided to go with the rubber because the new rubber is far superior to the old stuff, and because I've tuned cars/bikes to a point where I no longer enjoyed them as much. Its tough because this is my first 911, so modifications are based around balance....kind of using new technology (WEVO shifter is a good example, and new rubber) and what the factory would do if they could create a good street car today. I'll do some track days, but the majority of my driving is on the wonderful mountain and canyon twisties in Colorado, so I want to make sure the car works best on those roads.
Chuck and I discussed this for a while and he thought this would meet my goals very well.
'69 Honda CL350
Old 12-31-2012, 04:29 PM
1984 Porsche Carrera
ozracer's Avatar
Enjoying watching your rebuild.
What made you mix Bilstien shocks though HD on the front and sports on the rear?
Old 12-31-2012, 07:40 PM
Air Cooled
Craig_D's Avatar
Hi ozracer, thanks. The Sport Bilstein shock is a stiffer dampened shock than the HD. I already had the new Sport shocks on the back, so we matched the spring rate of the torsion bars to the Sports. Then, the front Bilstein was totally rebuilt and valved specifically to match the rear shocks and the new torsion bars up front. Chuck and I talked about the rough weight of the car, the sway bars, what tires (and wheel sizes) before he revalved the fronts, so it's really a matching set. Does that make sense?
I know a number of people who mix HD and Sports depending on the mods on the car, and the weight, and in my case it's pretty well matched to the spring rates and sway bars.
'69 Honda CL350
Old 12-31-2012, 08:35 PM
GaryR's Avatar
Send a message via ICQ to GaryR
I have put ER Polybronze on every 911 and 930 (4 so far) I have and would never go back to rubber. All you need to do is see once how effortlessly and in-plane the front and rear arms move compared to (any) rubber. Five minutes with a grease gun every oil change and forgetaboutit. Also would go ER monoballs in the trailing arms and shock towers to eliminate changes in geometry there also, but that's just MHO..
Gary R.
Old 12-31-2012, 08:46 PM
Demetri's Avatar
These are great pictures! I hope to be doing the same soon, and this thread is going to help! Happy New Year!
Old 12-31-2012, 09:35 PM
Eva
911SauCy's Avatar
I know this is a bit off topic, but I can see a nice exhaust set-up I am unfamiliar with.
I'm trying to make a decision on header/muffler combo for my '78SC 3.0...
Any info is greatly appreciated
Old 01-01-2013, 08:46 AM
Craig,
When you order the spacers make sure you get a pair of rubber o rings goes on the spindle before the spacer. Just a heads up and very nice build. I'm about to reassemble my car as well with a set up like yours.
Old 01-01-2013, 09:07 AM
Air Cooled
Craig_D's Avatar
'Mornin guys and Happy New Year! Thanks for the encouragement, I'll be heading out this afternoon to work on the other bushings and will post some pics.
911SauCy, here is a link to my custom exhaust build: Craig_D's Dual Cat SC Exhaust
I mocked it up using SketchUp 3D software and then worked with Hank Padilla at Hanksville Hot Rods to create a light weight, high performance exhaust that also passes 50 state emissions. Love it! ...and it sounds like a hot rod 911 should.
Abby3.2Carrera, thanks for the tip. I ordered this guy with the spacers.
GaryR..hmmm interesting. Well I've budgeted for rubber bushings and am committed to seeing it through because one of my concerns was additional NVH. I'm trying to strike a balance between additional sportiness and ability to enjoy the car on bumpy tarmac in the mountain passes. Plus I've gotta keep within my budget as I have a lot of winter projects to fund.
'69 Honda CL350
Old 01-01-2013, 09:27 AM
AutoBahned
RWebb's Avatar
I also have the polybronze on my street rod - BUT Steve Weiner has posted that most of his customers prefer the Elph. rubber - and I doubt that they are 'ordinary' 911 drivers.
You should be fine.
Here are impressions from a back to back test of 2 cars over the same roadway:
Yet Another Boring Rgruppe Car – Part II, Suspension
Old 01-01-2013, 10:32 AM
Air Cooled
Craig_D's Avatar
Hey RWebb thanks for that link. Interestingly, I had read that before and it was one of the reasons I'm going light on stiffness for bushings and torsion bars. I'm really interested in feeling the car respond to these more mild upgrades before jumping into a set up that makes the road manners harsh. I guess I'm aiming at having some rally car feel/compliance so that I can go quickly over real roads and not skitter wide over the washboard. I thought your findings were great to consider, so thanks for your post!
One question for you; I'm toying between the rubber strut uppers, and the sealed mono-ball uppers. Any thoughts on the merits vs trade offs here?
- Craig_D
'69 Honda CL350
Old 01-01-2013, 02:59 PM
AutoBahned
RWebb's Avatar
I used new rubber strut uppers & am happy. I know I've seen some comments before on that but don't have a link.
I've found that what P AG did with the RS cars is a pretty good guide for me. The RSR cars less so.
What is good one one road will change on another; same for the track; same for a road trip with a passenger...
Old 01-01-2013, 03:09 PM
