Originally Posted by Classic 911
That’s right. The 3.2 case/block looks like this from the side. Picture showing the left side.
On the bottom side you can see the oil drain plug.
Ahhh yes, mine is a SC case for sure.
Originally Posted by fanaudical
Nice find!
The "WTF is this" caption above points to the bellows cap for your rack and pinion. The rubber bellows snaps on to that so it can accordion in/out as the rack shifts.
Oh, I know exactly what it is, I was more referring to the comical idea of using a rubber joint in a tie rod end
