LinkBack | Thread Tools | Rate Thread |
Petrolhead
Brake lights and sunroof stopped working after replacing turn signal switch 76 911
A few days ago I replaced the turn signal switch on my 76 911S.
After the replacement, the low beam, high beam, and all functions related to the switch worked fine. However, I noticed that both the brake lights and the sunroof stopped working right after I installed the new switch. ![]() Could these issues be related to the turn signal switch replacement, and if so, what should I check first? Thanks in advance for any suggestions!
1976 Porsche 911 S, Coupe 1978 Porsche 911 SC, Targa 1983 Porsche 911 SC, Coupe 1983 Porsche 944 Coupe |
PCA Member since 1988
Check fuses first. Otherwise, it's likely that you pulled or bumped something that loosened the connections to those circuits.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Petrolhead
So now it΄s just the brake lights that must be fixed. Not sure how long they have been out of work, so I start by checking the brake pedal switch and see where the power ends.
