Now to start pulling off the exhaust. Found some interesting things.
The joint between the heat exchanger and the crossing exhaust pipe on the 4-5-6 side was full of oil. Probably half a cup came out when I opened that part up. Note that my destroyed valve was 3. Taking off the heat exchangers wasn't as tricky as I feared. The inner bolts on the exchangers were actually just stacked with washers, maybe as a stand-off? Not sure how that worked. But that meant I just had the 8mm studs and then 3 nuts per side. 4-5-6 side was pretty oily, especially at 6. http://forums.pelicanparts.com/uploa...1751636537.jpg 1-2-3 was not as oily. Here's a video of her as she stands now. (May take a minute to be available). https://youtu.be/6zh79LVmjPE |
Video of the from the top. Three is the boomed cylinder.
<iframe width="560" height="315" src="https://www.youtube.com/embed/D9G9zfOnCsM" frameborder="0" allowfullscreen></iframe> Video from the bottom. <iframe width="560" height="315" src="https://www.youtube.com/embed/HEfylfChkLI" frameborder="0" allowfullscreen></iframe> |
Obviously I want to know why this happened.
Is there anything I should note, record, or measure as I take things apart to help me identify the cause? I'm trying to take a lot of photos and some good videos, but I don't know what to look for besides "the broken parts" and "lots of oil/dirt" where it shouldn't be. |
Take pictures as you disassemble it. The valve guide is gone, so I would want to know where that went.
Good work, Opening the chain box covers should be enlightening. I noticed in the video the sump cover is on, did you take it off to drain the oil and then put it back on ?
Cam housing covers are now off. I need to identify the correct Porsche Tool(s) to remove my camshafts. I took some careful pictures, so that should help me identify the right ones. Then while I'm waiting for the special tool, I can clean things up. http://forums.pelicanparts.com/uploa...1751724891.jpg http://forums.pelicanparts.com/uploa...1751724891.jpg http://forums.pelicanparts.com/uploa...1751724891.jpg |
Engine Rebuild Subforum Thread |
i know this is off topic, but how loud is that exhaust setup your're running? |
Hi Mike. Pretty loud WOT. Burbles a bit at idle. I can drive it under the noise radar, but when I’m on it you notice me. Lots of compliments at the track on how nice it sounds especially when bouncing off a wall.
Big surprise in the engine teardown thread - the camshaft bolt was loose! Going to see where this leads...
https://forums.pelicanparts.com/911-engine-rebuilding-forum/1179839-1979-sc-chewed-valve-total-rebuild-2.html#post12493691 |
I think I may have located the instigating failure. The rocker shaft on the valve rocker that failed was far far out of alignment.
https://forums.pelicanparts.com/911-engine-rebuilding-forum/1179839-1979-sc-chewed-valve-total-rebuild-3.html#post12494493 |
I must be getting old... looking for something quieter these days :) |
| All times are GMT -8. The time now is 11:53 AM. |
