Header adaptor gasket gaps help
Georges euro headers and adaptors. No matter how I arrange these or order of tightening there’s always a substantial gap. They seem to bow when bolts are tightened. Any ideas? The mating surface is flat. Thicker gasket? What’s the trick?
1975 911 3.4 outlaw/hotrod? lsd
1988 535i
1987 535is
1973 bronco ranger
Old 07-12-2025, 07:49 AM
Maybe hammer a reverse curve into the more flexible side.
206 637 4071
Old 07-12-2025, 08:45 AM
Yeah. I put the ears in a vice and bent them back a bit. Problem is the 90 degree from there. Or top and bottom is where the gaps are not the sides with the bolts. This should be crushing this gasket.
1988 535i
1987 535is
1973 bronco ranger
Old 07-12-2025, 08:47 AM
My big 12” sanding disk would work.
Old 07-12-2025, 09:33 AM
Yeah. I had to grind a bit to get the header side flat. Looks to be sealing now. Bit of a puzzle to get all these things to mate flat.
1988 535i
1987 535is
1973 bronco ranger
Old 07-12-2025, 11:05 AM
porschetub's Avatar
Yep thats what I used but 8 inch,warped flanges on my muffler ,take your time and check with a straight edge, new factory gaskets and all is good.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 07-12-2025, 05:35 PM
A930Rocket's Avatar
I would think if the ears are bending, grinding them flat would only make them thinner, and flex more.
If the flange was thicker, it wouldn’t bend (as much).
Maybe double the gasket up, but make sure you’re using a quality metal backed gasket?
Old 07-12-2025, 06:29 PM
I’m not to sure about doubling up the gasket. I would think it would exasperate the problem. A thicker flange would help immensely.
Old 07-12-2025, 09:10 PM
Taking another look, how about welding a thicker flange on the existing.
Or go to a V-Band Clamp joint.
https://www.ievilenergy.com/products/v-band-clamp-with-flange-quick-release-stainless-steel
or
https://ebay.us/m/LpRPOh
or replace the joint
https://ebay.us/m/Usznlz
or add repair doubler
https://ebay.us/m/JEBCxz
Old 07-13-2025, 07:15 AM
It's a 914 ...
stownsen914's Avatar
Sounds like you may have it fixed now, but I'd guess something was tweaking the header extensions and trying to bend them relative to the header flange. In the middle pic in the first post, it looks like the extension farther away from the camera is at an angle compared to the header. Sounds like the grinding you did addressed that.
Old 07-13-2025, 08:10 AM
