evan9eleven's Avatar
Removing stub axles - wheel bearings required?
Hi everyone!
I'm finally getting around to some long overdue CV joint maintenance on my '81 SC. I've read the epic thread on the subject, well worth your time if you haven't seen it:https://forums.pelicanparts.com/porsche-911-technical-forum/222537-reconstructing-constant-velocity-cv-joints.html
While I'm in there, I decided to do the upgrade to the later Carrera 108mm flanges and axles. I've procured the billet transmission flanges from CMS, the '86-'89 rebuilt GKN axles with the integrated stub axle from our host, plus new bolts, Schnorr washers and moon plates. All the parts Grady and others listed up in the thread.
My question is this: Once the castle nuts on the end of the stub axles are removed, how best to remove the old 100mm stub axle flanges from the hubs? Can it be done without damaging the wheel bearings?
Lots of threads about axles and CVs, some mention how easy it is to ruin rear wheel bearings, but I've not found anything specific that answers my question.
Thanks in advance!
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 07-24-2025, 08:20 AM
The stub axle should come apart from the hub without damaging the wheel bearing...if nothing is seized. If it comes out easily, you should not need to replace wheel bearing or remove the hub.
You'll likely need to whack the stub axle out of the assembly from the front. I use a large brass punch.
Old 07-24-2025, 09:45 AM
Thanks! Here's to hoping it isn't seized up.
I thought I read somewhere that hammering ithe stub axle out was likely to cause wheel bearing damage. I'm thinking that penetrating oil and caution will be my friends here.
2004 Boxster S
Old 07-24-2025, 01:44 PM
Both times I pulled my axle stubs, once for a worn out bearing and once when restoring my suspension, the bearings came apart. The bearing is a split bearing and one half remained on the stub axle. May want to plan on new bearings while doing the job. With the tool it’s an easy job. It’s actually harder to get the bearing half off of the axle stub vs getting the bearing out of the housing.
Doug
74 Carrera Targa #9114410208
Old 07-24-2025, 02:06 PM
I've only done rear wheel bearings a few times.
half the outer bearing race always comes out with the stub axle; new bearings each time.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 07-24-2025, 02:23 PM
E Sully's Avatar
Plan on new wheel bearings. Both of mine came apart when I pulled the stub axles.
Ed
1973.5 T
Old 07-24-2025, 02:24 PM
A930Rocket's Avatar
It seems like if you’ve gone that far, installing bearings would be prudent.
Old 07-24-2025, 03:34 PM
I just took out one axle to fix boots - bearing stayed where it was, I left it alone...
1986 Carrera 3.2 Coupe in Grand Prix White
IG: @c.cal.porsche
Old 07-24-2025, 03:43 PM
Thanks everyone! Bearings it is. Probably smart to do them while I'm in there anyway...
2004 Boxster S
Old 07-25-2025, 05:18 AM
The stub axle can be removed without creating any damage to the bearing as long as no weight is put on the wheels while the stub axle is removed. If the wheel flange is removed the bearing will be destroyed.
Old 07-25-2025, 06:36 AM
A little follow up.
Note that I referred to stub axles in my original post. That is the correct term for the part I was referring to-- the stub axles that mate to the half-shafts at the outboard (wheel) end. The other end at the differential is the transmission flange, and the wheel hub is the outer part actually inserted into the bearings.
Many confuse the stub axles and wheel hubs. I had them right, but hadn't ever taken this stuff apart to completely understand how all the parts relate. So for the sake of getting it right for future generations:
1) As several commented here, removing a stub axle from the backside of the wheel hub shouldn't affect the wheel bearings at all, as long as it releases from the hub without drama. Mine slid right out. If a stub axle is seized into the hub, it may be possible to damage a bearing if pounding out the stub. But the stub axle doesn't contact the bearings.
2) The wheel hub is what is pressed into the inner races of the wheel bearings. Removing this part will trash the bearing. Many threads show the process of removing this part and replacing bearings.
In my case, I could have left the hubs and bearings alone and just pulled the axles out. But I went all in and changed them since I had everything apart anyway.
Thanks for the help everyone, I learned a lot doing this job!
2004 Boxster S
Old 08-06-2025, 06:40 AM
You got it right.
Old 08-06-2025, 01:05 PM
Stub axle
Once the nut is off and the axle is disconnected the stub axle should pull/push out easily.
The hub is easily removed with a slide hammer, correct nut and washer on the end. typically it doesn’t trash the bearing. get a loaner from Autozone.
Use a bearing puller (autozone loaner) for the bearing. The kit, with all of its combinations has the threaded rod, large open ring that goes on the outside of the hub(allows the bearing to come out with maintaining pressure on the washer against the back of the bearing), the correct size washer to sit against the bearing, and the nut that goes on the end of the threaded rod. Tighten it down and the bearing will ease out.
Old 08-06-2025, 04:27 PM
gearhead
Originally Posted by Locker537 View Post
You got it right.
^this.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 08-06-2025, 04:56 PM
https://www.pelicanparts.com/More_Info/93033223205.htm?pn=930-332-232-05-OEM
Now I don’t know what to call them. In the link above, Pelican calls the piece that goes through the wheel bearing the stub axle.
Doug
Old 08-06-2025, 05:11 PM
Then you do know what to call them, as the part you linked to is the stub axle. Just as I described it above. That part is connected to the outboard end of the axle and inserts into the backside of the wheel hub, which is the part that is actually pressed into the wheel bearing. So there is no contact between the stub axle and the bearing. The stub axle is the centermost part of the assembly, then the wheel hub which is pressed into the bearing inner races, then the rest of the bearing, then the trailing arm the bearing is pressed into.
Trailing arm with bearing removed:
Bearing installed:
Parking brake assembly and bearing retainer plate reinstalled:
Here is my wheel hub as I'm pressing it into the inner races of the new wheel bearing:
Here are my old and new axles; look at the top two. Both of them have the separate stub axles still mounted to them. The bottom one is the later Carrera version where the stub axle is no longer a separate part.
2004 Boxster S
Old 08-08-2025, 05:19 AM
