Calling alternator experts
I have a 1990 engine with an alternator that is not charging, and it's not the alternator problem. There are only 3 wires going to it.
12V, checked that it connects to the starter and then the battery. Good.
GRD, checked that it see 0 ohms to the body, good.
Excitation terminal.
So what voltage should I see at the excitation terminal when the key is at "Start" position? 1/2/3/4 or 12V ?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-28-2025, 02:01 PM
You should see roughly battery voltage at that wire
Old 07-28-2025, 02:45 PM
While the engine is cranking, I should see battery voltage at the excitation terminal?
Old 07-28-2025, 03:40 PM
PCA Member since 1988
I'm not sure about 1990 engines, but earlier engines relied on voltage supplied through the generator warning light to excite the field. Did you replace your gen. light with an LED? Is it burned out?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-28-2025, 11:36 PM
Yes, the excitation terminal is fed ...
Igntion On wire (12v with key on)
to Positive side of the Gen light
LED light (since removed and replaced with simple bulb) (on a side note, where do I get one of the LED thing?)
to negative side of the Gen light
to the Excitation terminal of the alternator
At key off, the E terminal of the alternator is close to ground
At key on, the E terminal of the alternator is less than 1V and the G light on the dash is on.
What should it be while cranking in order to excite the alternator? 1V, 5V, 12v?
Old 07-29-2025, 05:58 AM
Clock issue?
206 637 4071
Old 07-29-2025, 07:05 AM
To "start" the alt charging, the terminal current needs to be greater than 100ma via the bulb.
Dave
Old 07-29-2025, 07:10 AM
Originally Posted by john walker's workshop View Post
Clock issue?
Please explain?
Old 07-29-2025, 07:55 AM
So if the bulb is 50-60 ohms, that would be enough.?
Old 07-29-2025, 07:59 AM
Many circuits go through the clock. Does the charging light in the clock light up with the key on?
206 637 4071
Old 07-29-2025, 08:18 AM
Well, it's a 71 body with a '90 3.6L engine. The gauges are not original to the 71 especially the speedo and tacho. The charging light was changed to an LED which I took out and replaced with a regular incandescent bulb. I am not sure if the clock is doing much if anything.
Old 07-29-2025, 11:13 AM
Assumed it was a 964. You didn't say '71 body.
206 637 4071
Old 07-29-2025, 12:03 PM
Well, OK. It turned out to be a very bad battery that caused everything... including no alternator excite ...
All is now well.
Old 07-29-2025, 02:12 PM
