kpfoten's Avatar
This is a great thread! What about books? I've seen all these body shaping tools (thighmaster?) but I always wondered how to use them. Seriously, is there a good book out there on metal fabrication?
Thanks!
Kris - '77 911S
Old 10-02-2003, 02:51 PM
You do not have permissi
john70t's Avatar
I've been practicing with a Lincoln 135 plus and it is awsome.
An associate who works for Praxair welding hooked me up with a great deal and explained it's advantages (I hope I remember this correctly):
It has a copper vs. an aluminum "choke" so the voltage fed to the wire is constant when the tranfer is pulsed.
It (plus version) has an infinite variable settings, although I haven't noticed too much difference(still a novice).
The Lincoln vs. the Miller has a flexible wire output housing so it doesn't break when you carry it and accidently bang the wire feed cable into something.
My only gripe was it didn't have superfine control to contiunous lap-weld steel can edges, but if you have the patience to tack spots all the way around and grind them off the welder should be able to attach sheet metal.
BTW: I saw this program(discovery channel?) where they welded panels for a Finnish cruise ship (the largest in the world) underwater so there was no buckling at all.
Old 10-02-2003, 05:30 PM
Thumbs up
I have the 135plus it is excellent. If you want to do heavy work make sure you have a 20 amp/120 volt supply. I haven't used my stick welder since I got the 135. It will weld paper thin and heavy structural stuff. i also have a sandblast cabinet, definately handy.
Good Luck
Woody
KEVIN WOOD
70 911E TARGA
Old 10-02-2003, 06:58 PM
Autobahn Garage
Don't forget to check Harbor Freight Tools. There in Ohio,Mich, Ind, Penn, Good tools cheap. Not always the best quality but they will warranty almost all there stuff!!
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 10-02-2003, 08:59 PM
Send a message via Yahoo to RichMason
I bought a 135 plus as well and have had good results...now if I just had time to actually finish the damn thing...
Rich Mason
87 951 for sale $5500
Old 10-03-2003, 01:31 PM
