jm58's Avatar
Question 3,6 conversion erratic issues
Hello everybody
I am the next on the list looking for answers after reading a lot of similar but not exactly same issues
I think it's not necessary to write a long text to explain what happens when I can show this in video: https://youtube.com/shorts/1Ntx1oeC0Q0?si=E_K9IN_dH-0O_5Ul
Then later, without engine starts: https://youtube.com/shorts/JhhMPtPf4J0?feature=shared
Anyone has a clue from the root cause of that ?
Thank's a lot for your help if you can.
JM
Old 08-14-2025, 02:40 AM
Jaskas's Avatar
Is it the ICV which is making that weird noise?
911-87 mit der 3.6 V-Ram und alles spaß
Old 08-14-2025, 04:36 AM
jm58's Avatar
Not only the ICV also all connected system such as bleeder and vacuum valves
Old 08-14-2025, 05:29 AM
jm58's Avatar
I hope that someone who faced the same issue will read my concern, today when I switched on ignition I've got the same "buzzing" noise so I managed to unplug one by one each socket ,ICV, venting valve, bleed valve, knock sensors, air flow meter, idle and full load switch, no change till I unplugged temperature sensor=> buzzing noise stops.
I checked resistance of this NTC temperature sensor which shows 1900ohms for 27°C, this is correct, so my question is there anybody who have had this kind of problem with temperature sensor? Is it possible that it could have spurious fault?
Thank you
JM
Old 08-17-2025, 01:41 AM
Can you identify what is rattling via a stethoscope?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 08-17-2025, 09:18 AM
jm58's Avatar
I did, without stethoscope, I identify the ICV, shift valve resonance flap, tank venting valve which are rattling,I have checked the power supply of these components,,they are on the same line, it was 12,3 volts which is correct.
it's very difficult to understand because sometimes it quickly vanish and I guess that is related when the car completely stalls or has just some hesitations...
Old 08-17-2025, 09:40 AM
jm58's Avatar
Old 08-17-2025, 09:41 AM
3rd_gear_Ted's Avatar
The DME pulls circuits to ground to actuate an output device.
Check the ground side of each device with a meter and get physical with the wiring, monitor for changes.
Not an expert, just a logical step it seems to me.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 08-17-2025, 07:04 PM
jm58's Avatar
Thank you Ted.
I would like check but I think that the ground is monitored by the DME so I don’t know how to do.
Old 08-18-2025, 12:31 PM
