Voltage regulator or alternator?
The speedo in my 3.2 recently stopped working. Leading up to this, there were a few occasions while driving when the needle would go crazy for a couple of seconds, and then go back to normal. I sent the speedo out for repair, and the guy found several components on the board fried. This is making me suspect that my voltage regulator is going bad. I don't want to do anything more until I get that resolved. I tested the charging voltage at the battery at 4000 rpm and it looked normal, 14v or so. But the speedo needle issue seems to suggest that the problem is intermittent and could keep happening.
From the records I have, I know that a previous owner replaced the alternator with a new Valeo one in 2012. Since then the car has only had 18k miles put on it. To me it seems unlikely that the alternator itself could have gone bad in that time. Does it make sense to try just replacing the voltage regulator first? |
The regulator is on the alternator. You will have to remove the alternator to get to it. If you have a local rebuilder just take it to them, or replace the regulator and maybe the diodes.
It is not an easy project to get the alternator out and back in. The air diverter on the back of the alternator leaves little room to work.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Bland
I just did the voltage regulator in my 86 930 a few weeks ago. I bought the inexpensive one from our host, it looks different than the original but it fits and works just fine. I’ve got 2.5 tanks of gas through the car since.
My guess is that you may have a damaged signal wire or poor connection at the transmission. When the VR acts up, your tach starts to drop to 0 first.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Driver
I had problems similar to the OP's in my '87 930. For a few seconds, the tach would go nuts, bouncing all over the place while I was driving. I hooked up a multimeter to my battery terminals and saw how the voltage would spike up to 16 volts while this was happening. I was fortunate that nothing fried. I replaced the VR (and the alternator while I was at it, as they're piggybacked on top of each other and I didn't know the age of the alternator--it's about as much labor to replace one compared to the other).
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
![]() My main thing is that I'd rather not replace the whole unit, at a cost of almost $1k, if only the regulator ($120) is bad. I understand that I have to get it out either way. |
Driver
I didn't find the overall job (of VR and alternator replacement) too difficult for even my own shadetree mechanic abilities.
I’m all for original parts, but I’d probably go with Valeo for $400 vs $1k if you can’t find a good local rebuilder.
Ah. I didn’t see you were in Aus.
Your alternator and VR may be OK. Before you ditch them you may want to do a few test runs. May be plug a voltmeter in the cigar lighter, preferably an analog meter with a needle and not a digital meter, as a DMM might not see very short pulses while an analog meter will bounce and let you know if your electric system is going mad. Do this while driving, with the engine at various RPM. You may find out that your alt and VR are OK. Maybe it was only a speedo failure that is now repaired and you can plug it back in.
Gilles RoW 88 Carrera coupé Last edited by wazzz; 08-23-2025 at 12:22 AM.. |
PCA Member since 1988
I have pulled the alternator in and out of my car enough times that I think it's pretty easy, and I have size XL hands. The first time you do it, pull the wires to the alternator into the shroud and much as you can, and you will get another inch or more of wire length. That doesn't sound like much, but it makes a real difference in working space. The ground wire/strap from the alternator to the engine frequently is the shortest, and you can replace it with a longer strap, or move the eye from one of the case bolts to a closer case bolt, which will give you more room to work "next time."
Agree with Gilles on using an analog voltmeter to check for voltage spikes. A loose blue wire might cause voltage spikes, because the alternator gets its field current through that wire. If the wire is loose, the field current, and thus the output voltage, will jump around. Therefore, when you first remove the alternator, check the connections to the alternator to see if any are loose or corroded. If so, you might have a no-cost repair.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 08-23-2025 at 10:27 AM.. |
Still here
Not getting the "difficult" job part.
Remove the belt, undo the strap, remove the air diverter, remove the alternator, replace the regulator. |
Bland
The VR is sub $30
