cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Cell Phone Holder
Has anyone found a good solution for mounting a cell phone in an older (89) 911.
I dont like the suction cups, they tend to always fall off.
I dont like the vent clips as they also fall off.
My phone has a case so I dont think the magnetic versions will work
the cup holders on my car are flimsy so prob not the best solution
someone must have figured this out.
Chris
89 Carrera
Old 03-15-2023, 05:20 AM
Been here a while
rennline has a cool ring that mounts around the clock and you can position the phone in just about the ideal location. Leaves no marks, very unobtrusive.
I highly suggest the magnet, especially with apple products, add a thin steel ring to the outside of your case and the phone will NEVER fall. But, if you insist, you can mount any kind of clamp mount you like to the rennline ring mount. I'm sure our host has this available.
looking for 1972 911t motor XR584, S/N 6121622
Old 03-15-2023, 05:56 AM
Rennline mount. I have two. Great product.
Old 03-15-2023, 05:59 AM
I have installed the metal plate on the Renline
phone mount behind the phone case and it still holds the phone on the magnet
Old 03-15-2023, 06:06 AM
cmcfaul's Avatar
Thanks,
I will give the Rennline a try.
Chris
89 Carrera
Old 03-15-2023, 06:26 AM
I have a Rennline mount in my VW wagon, holding an iPhone with the magnet behind my case. Works well most of the time, but over large, sharp bumps the phone will fall off. When it bothers me enough, I can always replace the mag mount with a clamp mount. I have another one waiting to go into the 911. Minor annoyance: the set screw included is an odd size, included in none of my many allen wrench sets. Wrench not included with mount.
'80 SC Targa
Avondale, Chicago, IL
Old 03-15-2023, 07:32 AM
I have the Renline one as well. With the magnetic flat base it works quite well with my iPhone.
I can unscrew the magnetic base and that leaves a ball mount, that my GPS just mounts to. It would well, is not on the dash or windshield. Windshield mounts are illegal in some states.
Old 03-15-2023, 12:03 PM
walt's Avatar
I wanted the Rennline mount badly however, the magnetic plate I thought would interfere with wireless charging. I would hate to loose that feature on my phone.
Walt
82SC 3.0
81SC 3.6
Old 03-15-2023, 12:08 PM
Been here a while
there's a MagSafe supported ring that allows charging, yet keeps the phone well stuck to the mount. I bough 6 spare rings for a few bucks on the amazon.
Old 03-15-2023, 12:26 PM
walt's Avatar
Found it, never knew of these. Thanks,
Walt
82SC 3.0
81SC 3.6
Old 03-15-2023, 01:14 PM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
For my '87 I made a cell phone holder that is secured by the open ashtray. It works fairly well, and I like that it is high enough to see but not directly in my line of sight, but of course one cannot use the ashtray while using it.
Old 03-15-2023, 02:19 PM
fallingat120mph's Avatar
Originally Posted by cmcfaul View Post
Thanks,
Chris
89 Carrera
I have the Rennline and have driven thousands of miles with it. Love it, but...
Couple things.
1 - I had two and broke the first one trying to get the knob/ball tight enough to keep the phone in place (Given this was years ago, new ones may not have the issue). The ring itself is an easy mount.
The second one I ended up making sure I knew exactly what angle I wanted and where I wanted my phone and didn't tighten too much and ended up using a tiny amount of super/gorilla glue to hold in place. It's been perfect. Just an FYI in case you encounter the same issue...for the price shouldn't be that way...but it is what it is.
2- I have an aftermarket system and wanted the phone to plug into the stereo to connect and to charge. The cable from the USB port to the phone so that can get in the way of shifting in town, etc...so again, just an FYI.
EDIT: I have the magnet and have no issues. The one included does real well on the phone case. I have two cases...I keep the magnet case in the 911 and swap when I drive...
Being in south Texas and doing cross country drives 2-3 time a year the Rennline has been great.
Good Luck!
Erik
1986 911 Coupe
1986 911 Targa
Old 03-15-2023, 02:46 PM
It does. I bought two cases and swap out when driving the 911.
Good point to bring up.
1986 911 Coupe
1986 911 Targa
Old 03-15-2023, 02:51 PM
Chris
89 Carrera
A friend of mine has designed a holder that clips onto your ashtray and accepts a VERY wide range of phones.
Here's a link to our listing on FB marketplace..
https://www.facebook.com/marketplace/item/981659593212921
Yes, we are in Australia, and yes, it works on Left Hand Drive cars too
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 03-15-2023, 03:04 PM
Here's a link to our listing on FB marketplace.. https://www.facebook.com/marketplace/item/1201532387116240
Great option - nicely done.
1986 911 Coupe
1986 911 Targa
Old 03-15-2023, 03:10 PM
Thanks.
We've sold approx 50 or so here in Aus. All happy owners.
I've not sent any to the usa before, but if anyone is keen, pls get in touch. I think the current exchange rates make it very appealing if you live in the USA.
Always learning.
Old 03-15-2023, 03:12 PM
Ctopher's Avatar
I have the Rennline mount but replaced the magnet base which wasn’t that strong, with an Amazon misc wireless mount. It has a better magnet and it just snaps onto the same ball, most are probably interchangeable, and cheaper than buying their new wireless option.
Old 03-15-2023, 03:47 PM
I’d love to know more about that option, too. Facebook link led me to a dead end.
'80 SC Targa
Old 03-15-2023, 03:49 PM
sorry, didnt realise it was shared to a private group..
Try this?
Always learning.
Old 03-16-2023, 03:31 AM
Rennline makes an upgrade kit that a) works with the MagSafe system and b) allows wireless charging through the adaptor -- https://www.rennline.com/wireless-induction-charger-sku-pm70/
Don't have this yet (still using an iPhone X) but and a happy customer of the original rennline 911 mount and have a VERY secure fit using a magbak case on my iPhone.
Old 03-16-2023, 02:01 PM
