backdated dash question
I want to backdate my dash much like the picture here. Is the aluminum extrusion simply attached over the original dash or do you remove the original and then attach the extrusion. In the picture it appears to be over the original since the top part where the gas cap release is looks to be an original piece.
Old 08-19-2025, 09:07 AM
That knee pad is removed, has 4 nuts on studs that are tricky to reach that attach to underside of metal dash frame.
The all metal kneepad then takes it place using same mounting holes. Two pc. OEM kneepad fits either side of ashtray whereas the all metal alum one is one piece.
The gas door pull does not interfere or moved out of the way with either original or aftermarket. I believe the ashtray is eliminated at least the one I recall I was going to use.
Old 08-19-2025, 09:29 AM
there is a black foam like piece where the extrusion goes. Do you remove that too or just put it on top?
Old 08-19-2025, 09:48 AM
Not sure what where foam piece is….the gas door pull?
Removing kneepad is the pink part in your pic, or what I outlined. Essentially kneepad removes downward and is separate from all other components…
Edit : Thinking about yours, if it’s the “basket weave” section in your pic you refer to (?) and depending on the aftermarket kit you’ll be using, then that basket weave trim piece which is an overlay trim on early 911’s is removable but without it there will be holes, adhesive, maybe raw scratches on the frame that the trim hides.
Or in the case in which a retrofit kit with a new design of the +74 models comes as a complete set with some assembly order.
When I debated on this backdate, the glovebox and radio were required to be removed and I didn’t do the project.
Old 08-19-2025, 10:16 AM
this is the piece.
Old 08-19-2025, 10:32 AM
does the extrusion just attach over this piece of the dash?
Old 08-19-2025, 10:33 AM
I pulled the plastic off my 1975, and paid the extrusion down over the bare metal. Same on the glove box. My glove box does not fit as flush as I would like, and many of the early cars I have seen their glove box is not flush with the dash.....nor are many of the mid year cars I have seen.
I did think about knee pads with A/C vents in them when I re-did my dash, as I know I would be going A/C. With my Classic Retrofit system and my vent replacing the fuel/oil-level gauge I am thinking about eliminating those little vents not eh edge of the dash. On my car they often close themselves, and I don't notice there is a big difference in cooling. Might be a thought. I also don't have a radio am may put a second vent int eh radio delete panel instead of those 2 small ones at the edge of the dash.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 08-19-2025, 12:12 PM
Chris , did you leave he piece on the upper left that the gas door release knob fits in and the piece on the right side of the dash that the lighter and fog light knobs are? Nice gauges by the way, they look great.
Old 08-19-2025, 12:43 PM
May not be the direction you want to head, but this is the Rennline backdate kit that eliminates the glovebox and ashtray. And in my case, no radio either. (iPhone plugs into hidden amp...)
Their kit has the aluminum formed panel that eliminates all the foam pieces of the G body car. You can see how it fits around the gas lid pull.
It was a bit costly, but i've been pleased with the results. (Red basketweave came from Sonderwerks in CLT area)
Hope to see you at Luft11. Patrick
912E-3.2ss
Old 08-19-2025, 12:59 PM
I did not. I removed everything. I then painted the dash with black wrinkle finish. I love the look in my bothers E-Type Jaguar, and copied that. Works great.
Thanks on the dash. The green gauges are the current. John Bell here on Pelican did an amazing job on them for me!
Old 08-19-2025, 01:06 PM
Patrick, I have considered that and like it, very clean look. I plan to be at Luft by the way. I have not heard if my car was accepted yet, probably will not be. I will probably have Sonderwerks do my seats and interior leather work.
Chris, Bell does good work.
Old 08-19-2025, 01:26 PM
Luft put out a statement that submissions ended this past Sunday (8/17), and they will start making selections. Hopefully, some fun cars from the Carolinas will be there. Luft7 did have "air-cooled" parking only that was nice for attendees and fans to check out. Doesn't seem to be the case with this event, unfortunately. Sonderwerks did my sq weave carpet as well. Good folks.
912E-3.2ss
Old 08-19-2025, 01:49 PM
On the car in your photo, the basket weave inlay was applied on top of the existing dash trim pieces.
'80 SC Targa
Avondale, Chicago, IL
Old 08-19-2025, 01:55 PM
that is what it looks like to me also. It looks good to me and a lot less work than removing the existing pieces. Lots of good looking options out there, as the guys above have shown.
Old 08-19-2025, 02:13 PM
My foam pad had warped in one spot, and I wanted the metal channel slightly recessed, so I removed the pad and built up the area beneath slightly so the HVAC controls fit. I did clean up the area by the fuel release knob and painted it. I'm really happy with how mine turned out:
Here is a link to my post with more details:
https://forums.pelicanparts.com/porsche-911-technical-forum/1151536-my-school-project.html#post12172201
Korey
1984 911 Carrera 3.2 coupe (Strosek style wide-body, custom interior, ongoing project https://forums.pelicanparts.com/porsche-911-technical-forum/1151536-my-school-project.html )
2015 Alfa Romeo 4C Launch Edition (a few bolt on modifications)
Old 08-19-2025, 04:38 PM
very nice work
Old 08-19-2025, 04:49 PM
I love that floral print on the door panel!
'80 SC Targa
Old 08-20-2025, 09:11 AM
evan9eleven's Avatar
As others have mentioned, the Rennline dash backdate kit is a great way to go. You can have your trimmer cover the main part in leather, then make an insert for the center out of whatever material you like. You have to remove all the existing dash kneepads and foam padding, so down to the metal. The backdate dash cover then screws into the metal dash. You lose your glovebox doing this but the look is worth it IMO. Any holes for extra stuff like dash switches need to be drilled. There are knockouts for the radio and climate control.
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 08-21-2025, 03:44 AM
I agree, that is a good way to go. I go back and forth on losing my glove compartment. I do find it useful, but they never seem to fit well
Old 08-21-2025, 05:53 AM
Backdate Dash "glovebox"
Lol -- i found an attractive & portable solution to my now-cancelled glovebox. The Herschell nylon lunchbox. Perfect size to hold paperwork and original owner's manual.
it just sits on the floor in the passenger footwell or in the trunk. Patrick
912E-3.2ss
Old 08-22-2025, 05:51 AM
