Mocal Thermostat Location
Installing a new remote oil cooler on my 1974 911s ( the car never had one not even the trombone). Since I have had the stock 2.7 totally redone and built to a RS spec, it needs one. I purchased a kit from *********** which came with all required parts, except for better instructions. I have temporarily mounted the thermostat and am looking for feedback on this location. Does anyone see a problem with this.
use the oil lines to the front as a template to position it. The rear ones are much more flexible.
Bill,
Lines are flexible SS with AN fittings. Just concerned with wheel clearance issues. |
OK, unfortunately you can't see my t-stat but I relocated the oil lines below the crease for clearance w/ 275/40 x17 tires on 9.5ER19 wheels back space was ~6" on the tire.
