(man/dude)
Ride height Chart
Does anyone know the original source of this chart, and where I might find a higher res version of it? I get a headache every time I try to read it!!
![]() TIA!!!
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
I have a performance chart ~ the same res.
Sent from my SM-A115A using Tapatalk
Mill Beatty Coordinator for the 911 Carrera 3.0 North American registry site> |
911 Workshop Manual - printing # W313e also in Porsche Vehicles for Sport Purposes - printing # W351e
I applied some PShop to it.
![]() Still legible? Sherwood |
(man/dude)
Better, and thanks!! But I asked a friend to apply his talent and he basically re-drew a layer on top of the old. I have to get a better file from him but here's a preview. Ignore the typo (there's only one that I see)!
Special thanks to Cory for doing this!!! I'm going to print it poster size for the shop. EDIT - Wow it looks great!!!! EDIT - removed.....
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 Last edited by Jonny042; 03-25-2021 at 07:48 AM.. |
(man/dude)
Also a special thanks to Todd who sent me a nice high res copy of the "Sports Purposes" manual which I did not have. Good reading!!!
Ride
Perfect timing for a reprint!
Will come in handy very soon!
Paul 83 SC The Herring |
typos?
WC - Wheel Center TC - Torsion bar Center TCC - Torsion bar Cover Center
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Ok. I'll ask. Can someone explain how ride height is derived from this chart?
I got a headache even at the new size. Sherwood |
(man/dude)
But it's a good way to see where you're REALLY at compared to the factory ride height. Which is 108 front, 12 (above) rear, measured as indicated on the diagram.
(man/dude)
Final
Here we go, a final version....
front height___rear height___how much lower the car is from stock all measured by the factory method in mm note that the rear heights are pos. until the car is lowered 12mm from stock, from there down the #s are neg, alternatively use the absolute values and then think, is the WC above or below the TC? ![]() I added the factory method info and corrected the WC, TC, TCC notes
(man/dude)
While you were working I think we made some changes as well (including a few of yours). I'll get the full res version updated and post the final results again. Sooner or later it'll be 101% correct!!!
Thank you!
'95 Coupe (2025-??) '86 Coupe (2021-2025) '82 Targa (2018-2022) |
(man/dude)
PM sent!
Interesting chart. It shows that for every ride height the front TC is 120 mm lower than the rear TCC. Is that a golden rule? My car was recently redone and I have a 131 mm difference. So the front is possibly 11 mm too low? Or could there be a reason a shop would want a bigger drop? This is a 1973 911 with factory S front spoiler.
For most street use aero just isn't that significant.
