79 SC Plugged Rubber Pipe to Sensor Plate Boot
I have a California Spec. 79SC with EGR. The rubber pipe that connects the Aux. Air Slider was plugged at the Sensor Plate Boot. The replacement boot I am installing is also plugged but can be opened. My question is why would this line be plugged? See pics. Thanks!
Old 09-23-2025, 06:10 AM
I believe I have determine why it was plugged. This Aux Air Valve didn’t test good
Old 09-24-2025, 07:46 AM
How did you test it? The AAV is open until the engine starts, and vacuum is present. It then closes so air doesn't pass through it when running.
Old 09-25-2025, 08:11 AM
https://youtu.be/kSuNKcmwcKg?si=z1lY0Kp988LbovoF
Old 09-27-2025, 07:39 PM
