79 SC Plugged Rubber Pipe to Sensor Plate Boot
I have a California Spec. 79SC with EGR. The rubber pipe that connects the Aux. Air Slider was plugged at the Sensor Plate Boot. The replacement boot I am installing is also plugged but can be opened. My question is why would this line be plugged? See pics. Thanks!
I believe I have determine why it was plugged. This Aux Air Valve didn’t test good
How did you test it? The AAV is open until the engine starts, and vacuum is present. It then closes so air doesn't pass through it when running.
https://youtu.be/kSuNKcmwcKg?si=z1lY0Kp988LbovoF
