Distributor green wire connection question
My new 1981 SC's distributor has the green wire for trigger inputs.I"m missing the male connector from the CDI and I need to know how the two wires coming from the CDI are connected. With the notch on the female connector faced down, does the wire for the shielding go on the left or right?
Old 10-02-2025, 07:42 PM
Kroon Wire Harnesses
Cdi
Here you are !
7 and 31D
7 is signal
31D is screen
Specialized in Classic Porsche electrics
www.kroonwireharnesses.com
Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses
Old 10-02-2025, 10:10 PM
Thanks but my question is about the other end where the "signal" and "scree" go into the yellow connector on the green wire.
Old 10-03-2025, 08:19 AM
This has been covered recently in this thread.
Gilles
RoW 88 Carrera coupé
Old 10-03-2025, 08:34 AM
@wazz
Thx. I knew there have been several threads about the green wire but try to find them with the search engine. Impossible. Looks like if you do an engine swap from 3.0 to 3.2, for example,
you better swap the wires from the CDI !
Old 10-03-2025, 08:56 AM
