@massmike
Here you can see what a poor lambda reading looks like and what Dave and I are referring to: The amplitude is high, which can cause surging when the amplitude/reading remains at a high level for too long. And here is how it should look: Lower amplitude during oscillation = lower duty cycle amplitude = fewer low chamber pressure changes (in the fuel distributor) required via the frequency valve. @Dave The fuel control pressure is almost not affected by the flow in the frequency valve; the valve regulates the system pressure in the lower chambers of the fuel distributor. The higher the pressure in the lower chambers pushing upward against the diaphragm, the less the inlets above the membrane open toward the lines leading to the injection valves.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ Last edited by AndrewCologne; Today at 02:25 AM.. |
Post #1:
An upstream post suggested checking the warm control pressure. Have you checked it to the posted WUR specs? This can potentially contribute to the closed loop O2 system developing a greater Lambda correction - surging, as the system attempts to over-correct (15.3) ![]() To lean the mixture, the pin needs to move up.
Dave Last edited by mysocal911; Yesterday at 09:09 PM.. |
Please check the instructions in the link:
https://nineelevenheaven.wordpress.com/adjusting-the-warm-up-regulator/ Moving the small pin adjusts the cold control pressure, while moving the large dark component with the connections changes the warm control pressure. But if you mike don't have the skills, just ask Tony. Last edited by AndrewCologne; Today at 02:29 AM.. |
