Difference between US & Euro Bilstein Version 1 front strut cartridges
I've read 8+ different threads on the Bilsteins, and haven't found an answer to this question-
I've got a '85 coupe and I'm going to replace the original Boge units front & rear because they have over 215k on them... and I have stock torsion bars. I will never track this car.
Two different B6 front inserts are offered by Bilstein that have the settings that I desire (Setting: 2015/755)
#P36-0011 Version 1 -Front insert- US version with 7mm spacer
#34-001127 Version 1- Front insert- Euro version with no spacer
My question is this: I intend to lower the car (a little) to Euro spec, but no lower. Should I order the front insert with or without the spacer?
(Rear shocks are going to be the B6 Version 2 #24-001694 (Setting: 1965/1330)
Any info appreciated,
Dave
Dave
Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina"
PCA Member- Sacramento Valley region
Old 10-15-2025, 01:38 PM
Bill Verburg's Avatar
Dave
no spacer,
while the basic struts and inserts were interchangeable for all 911 from '72-89 only the US '76-863 used the spacers due to their higher ride height.
If you accidentilly aquire the struts w/ spacers just don't use them.
Bill Verburg
Old 10-15-2025, 03:08 PM
Thanks Bill. Also, I learned a lot about all the different Bilsteins from reading your posts!
Dave
Old 10-15-2025, 08:17 PM
