Navin Johnson
TimT's Avatar
I’ve had numerous people tell me PMO isn’t what it used to be. Race car mechanics, machine shop owners, etc.
Because its true
'69 911 GT-5
'75 914 GT-3
and others
Old 10-23-2025, 04:22 PM
Love this discussion. Looks like we have many good units to choose from. I’m somewhat new to this, but was introduced to ECU Master Black. It’s giving me sequential spark ( split my signal for dual COP), sequential injection, drive-by-wire for single throttle body, built in MAP sensor, built-in LSU 4.9 lamba controller, fuel press sensor input along with oil press and temp (designated as Coolant Temp for operational purposes). And using a few outputs such as one to open a resonance flap in the 964 manifold. I have a lot to learn and an upcoming date wirh local tuner to get me on the right path for this new 3.2SS build.
912E-3.2ss
Old 10-23-2025, 06:33 PM
From experience finding someone willing to tune an air cooled 911 is difficult. Find a shop that works for you, and see what they use. Will be a lot easier than finding someone willing to tune X ecu on Y setup.
Old 10-23-2025, 07:27 PM
MoTec or go home
North Idaho CDA / Spokane area
Instagram: to.performance
MoTeC USA Authorized Dealer
Porsche 959 Department Manager at Canepa *retired after 10 years*
Website / Webstore https://www.topperformancetuning.com/
Old 10-24-2025, 10:52 PM
Slow old car
Originally Posted by rwest View Post
Thanks Mike,
That would be the dream to have a shop to fall back on, but I have done a lot of searching and made many phone calls and if I had a Subaru, JDM or American muscle style car, I would be set here in MN, but I’m going to be on my own with a modified vintage Porsche.
If you don’t mind, what does Motec cost in hardware?
Rutager
The ecu (M130) itself was about $2400, but I also paid for a new custom harness, and added a second O2 sensor, and a bunch of other optional extras so my total cost was more than double that. Not cheap but I think there are much more affordable ways to get into MoTec than how I did it. That being said, I’ve put a couple thousand miles on it without a single hiccup since I finished it in May, so I’m happy to just have a reliable fun car after years of chasing ghosts!
Mike
1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX
Old 10-25-2025, 01:19 PM
One of the advantages of Haltech—compared to most other ECUs, possibly even MoTeC—is the built-in WiFi. My ECU lives under the passenger seat, so being able to connect wirelessly is a game-changer. I can drive around with my laptop and log or tune without a single cable.
Haltech also offers a mobile app that lets me monitor key parameters like RPM, oil pressure, and more in real time. I just connect my iPhone over WiFi and I’m good to go. You can even tweak some settings directly from the app. Here’s a look at a few of the app screens from Haltech’s site.
1980 911SC Targa
1990 S2 Cabrio (sold)
2004 C4S (sold)
2006 Boxster (sold)
Old 10-25-2025, 02:15 PM
Thanks Mile,
There is a Motec Dealer nearish to me, but their website seems like they specialize in Vipers. I’ll need to give them a call.
Rutager West
Old 10-25-2025, 07:02 PM
Originally Posted by TopTuning View Post
MoTec or go home
Top,
For a basic 911 setup, sequential COPs, ignition, 8 foot harness with ECU side plugs and IAC, what unit would be needed and approximately the cost. Would it come with a base tune and would that be an additional charge?
Thanks,
Rutager
Rutager West
Old 10-25-2025, 07:06 PM
[QUOTE=montauk;12553320]One of the advantages of Haltech—compared to most other ECUs, possibly even MoTeC—is the built-in WiFi. My ECU lives under the passenger seat, so being able to connect wirelessly is a game-changer. I can drive around with my laptop and log or tune without a single cable.
I looked up Haltech and there are about a half dozen local dealers, but once again they just do Asian and America cars or motorcycles.
The Maxxecu has Bluetooth and what appears to be an app. as well. Don’t get me started on apps... all it takes is the phone to update an IOS and the device manufacturer not too and you have a worthless app.
It appears that there are a lot of good choices of ECUs on the market, unfortunately not too much failure data available.
I appreciate the info.
What unit did you go with? It seems like you have to go pretty high up their line to get 6 cylinder sequential and WiFi?
Rutager West
Old 10-25-2025, 08:57 PM
I'm using the Haltech R3. It’s pricey, but it includes a built-in PDU, so you don’t need external relays. Large current loads are limited to four at 25A each. I’m running both the fuel pump and starter solenoid directly from the R3. While it doesn’t offer direct support for air-cooled 911s, that hasn’t been an issue for me. I leaned on the Haltech Facebook group a bit, but mostly I relied on ChatGPT to help dial in the settings. The AI was incredibly helpful. I’m sure a professional tuner could squeeze more power out of it, but for now, the car runs and drives perfectly fine.
I’m also using the ECU to monitor oil pressure and temperature with a new Bosch sensor. The ECU drives the original gauges, and I added a low oil pressure warning light set to illuminate below 10 PSI. Having the built-in PDU eliminates a lot of old wiring. I think the only wire left from the old engine harness is the alternator field wire, but I plan to move that over to the ECU as well.
As others have mentioned, your best bet is to find someone local that understands the ECU of your choice and 911's.
[QUOTE=rwest;12553454]
1980 911SC Targa
2004 C4S (sold)
2006 Boxster (sold)
Old 10-26-2025, 03:53 AM
The app is updated regularly and used by a lot of Maxxecu customers and actually very stable.
It is used primarily for displaying info like a motorsports dash, shift light and as a fault display like an OBD scan tool. Although the con is that it is only available on Android.
It does have some digital input functions like boost target selection, launch control on and off etc. The app like the EMS software is really flexible if you choose to use the toggle function.
You can choose to use it or not.
I use it on race vehicles sometimes when the customer doesn't have the budget for a motorsports display, or for stock vehicles that want to retain the stock dash but also have additional data streaming on the side.
On my personal car I use one of the app inputs as a kill switch when I park the car out in public as theft prevention.
For drive by wire vehicles I have also used it for a quick way to turn on a detuned "valet" mode so the car can't be abused when out of your care.
Sent from my SM-F741U using Tapatalk
Standard Competition Motors, Berkeley Heights, NJ | Maxxecu engine management and Plex tuning calibration specialist and supplier | chassis dyno tuning and calibration consultations
http://www.instagram.com/standard_competition_motors
Old 10-26-2025, 05:58 AM
ChatGPT to refine the tune! That’s kind of wild to me, but nor surprising. I’m curious to know more about the prompts you used, what you were asking it to do, that kind of thing.
[QUOTE=montauk;12553504]I'm using the Haltech R3. It’s pricey, but it includes a built-in PDU, so you don’t need external relays. Large current loads are limited to four at 25A each. I’m running both the fuel pump and starter solenoid directly from the R3. While it doesn’t offer direct support for air-cooled 911s, that hasn’t been an issue for me. I leaned on the Haltech Facebook group a bit, but mostly I relied on ChatGPT to help dial in the settings. The AI was incredibly helpful. I’m sure a professional tuner could squeeze more power out of it, but for now, the car runs and drives perfectly fine.
'80 SC Targa
Avondale, Chicago, IL
Old 10-26-2025, 11:43 AM
I'm no AI expert but writing about what you're doing, converting a 1980 Porsche 911 to EFI/ITB, and following up with a specific question seems to work. Then, as you have more questions, go back to that conversation. There's a problem I just found out about when I saw your post. I'm using microsoft Copilot, it's the paid version, and it's now telling me that it's deleted anything I've uploaded over 30 days old. So here's an example I just created of the process I used.
I wrote this and uploaded this chart.
I want to modify the fuel prime pulse on my 1980 Porsche 911 EFI/ITB conversion. Since it's aircooled, I'm monitoring cylinder head temperature not coolant temperature. Can you give me suggestions based on the chart I uploaded.
Here's the response:
1980 911SC Targa
2004 C4S (sold)
2006 Boxster (sold)
Old 10-26-2025, 05:50 PM
Keep in mind, AI gets things wrong - quite often in my experience. So you need to make sure that what it's telling you makes sense.
1980 911SC Targa
2004 C4S (sold)
2006 Boxster (sold)
Old 10-26-2025, 05:53 PM
A new offering.
Maxxecu has just made their GEN2 series public and are offering the Race model as the first one.
I have been aware and part of the discussion for quite awhile on this new version but was not able to speak about it until yesterday. I am really looking forward to start seeing these out in the wild and on my dynos!
Some of the features you guys have mentioned as important have been addressed.
The GEN1 series is still supported, will not be phased out and will continue to be developed alongside the new gen 2. They will both use the same Mtune software.
With the feature set and flexibility at it's price point it is incredible. The link below will get you to all the nerdy bits.
Introducing the all-new MaxxECU GEN2 RACE
Built for tuners, racing professionals, and anyone who demands absolute control.
When every millisecond matters; street, circuit, or dragstrip, the GEN2 RACE delivers maximum performance with precise data, ultra-fast response, and full engine control.
Highlights:
• Superseal 1.0 connectors.
• IP68 waterproof aluminum case.
• 550 kPa MAP sensor (4.5 bar / 65 PSI).
• 16 injectors / 12 ignition outputs.
• 16 GP outputs.
• 24 analog inputs.
• 8 pulse inputs / 8 built-in EGT.
• Dual Wideband Lambda.
• Dual CAN & dual knock.
• Dual USB-C.
• WiFi & Bluetooth.
• 3-axis accelerometer (up to 8 G).
• Dual Core CPU with 16GB internal log capacity, 1000Hz, all 1600+ channels.
MaxxECU GEN2 RACE – the next generation of engine control has arrived.
For more information, see https://www.maxxecu.com/products/gen2race
Old 11-20-2025, 11:45 AM
Im a bit of a dinosaur on this topic in that Im using MS1 on a bitz kit for fuel and a PE3 ignition only running my dual plug cop and cnp for sparks. I know I could run it all under one. How easy are the ones mentioned above for tuning? MS1 is super easy but limited.
Old 11-20-2025, 12:30 PM
I’m running a Haltech R3 with their NSP software. I wouldn’t call it easy — since there’s no Porsche base file, I had to work through a lot of settings. With each adjustment the car ran a little better, so it’s been a gradual process.
Right now I’m still fine-tuning the starting conditions. The car always starts, but my goal is for it to fire immediately with just the push of the start button, no throttle input, under all conditions. At the moment:
• On warm days (60–100°F), it starts right up.
• When the car is already warm, sometimes I need to nudge the throttle slightly.
• If it’s cold (below 60°F) and the car has sat for a week or more, I usually need to hit the starter twice.
There are settings to handle these scenarios — intake air temp and cylinder head temp can be used to adjust fuel prime, cranking fuel, post-start enrichment, and even timing. I haven’t fully dialed those in yet. Honestly, I haven’t touched the settings for a few months because I’ve just been enjoying driving the car.
1980 911SC Targa
2004 C4S (sold)
2006 Boxster (sold)
Old 11-24-2025, 04:50 AM
This is a great thread, as I tuned Subaru for about 20 years.
While not necessary for every vehicle/driver, I look at aftermarket ECU safety features for high-end/very expensive engine builds.
I have seen it firsthand, where an engine lost oil pressure during a pull on the dyno, and the ECU shut the engine off, saving the owner thousands of dollars.
Suppose you’re out and about, and you fill up at an unknown fuel station, and your engine experiences detonation/knock? You want an ECU that is going to react quickly preventing damage to your engine.
Old 11-24-2025, 08:13 AM
