Mounting engine mount bracket with bolt vs stud
Hi folks!
Sorry for the basic question. I’m almost done rebuilding a 3.0 engine to swap into my ’76, and when I went to bolt on the engine mount bracket, I realized the crankcase is missing the four M10 studs that secure the bracket to the case. Since the original studs are no longer available, I’m planning to use class 10.9 bolts in the appropriate lengths (40, 45, and 50 mm), but I wanted to get your opinions on whether there’s any issue I might be overlooking. Thanks ![]()
RSA Pinky Helga Turtle Carrera Luigi CDtdi |
PET '74-'77 911, Fig. 1-01-05, #02 999.062.090.02 Stud, M10x40 Qty: 1 PCNA List 2026: NLA
PET '74-'77 911, Fig. 1-01-05, #02/1 999.062.039.02 Stud, M10x50 Qty: 1 SS: 99906218302 PCNA List 2026: $8.28 PET '74-'77 911, Fig. 1-01-10, #02 999.062.090.02 Stud, M10x40 Qty: 1 PCNA List 2026: NLA PET '74-'77 911, Fig. 1-01-10, #03 999.061.056.02 Stud Qty: 1 PCNA List 2026: $3.17 For 999.062.090.02 try VW N90296401, ~$4.00 |
the studs make it easier to hang the mount on installation
Just be very sure the bolt length provides adequate thread engagement and super important, without any chance of bottoming out.
1986 Targa Guards Red 2021 MT09 SP |
Thanks folks. I went with bolts. I measured the depth of the stud holes (they are 25mm) and went with bolts long enough to go that deep.
Thanks Jimmy. This stud is also missing on my 2.7. I'll get the VW for that rebuild.
PCA Member since 1988
Using bolts instead of studs might make it easier to install and remove the engine mount and cross bar with the engine in the car.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
