Does a swing arm have to be re-plated?
Replacing bushings on rear swing arms and have removed all traces of original bushings with a wire wheel. Do the tubes have to be re-plated to prevent corrosion? I know one side will be completely covered by the new bushing but the other side will have part of it not covered.
1985 911 Carrera ROW
Old 11-11-2025, 10:17 AM
The 9 Store
Bare metal rusts. Even under a bushing.
All used parts sold as is.
Old 11-11-2025, 12:37 PM
I don’t have access to a local plating company. Is powder coating or an enamel paint strong enough?
Old 11-11-2025, 02:02 PM
A930Rocket's Avatar
That’s one reason I went with new arms.
I don’t think paint or powder coating would work, due to thickness and the material rubbing away, potentially loosening the fasteners?
Old 11-11-2025, 06:05 PM
I spray mine with Waxoyl once a year and it keeps rust at bay here in UK
Old 11-11-2025, 11:09 PM
The zinc plating which is then passivated (for even higher rust resistance) is there for a reason as im sure you know. If you can’t find a plater, there are ceramic protectants as well as oil based you can use but you’ll need to re-apply them periodically. They also wont help you with the area under the bushings or inside the tube - which is where mine had developed some rust.
Old 11-12-2025, 04:13 AM
Have you trued any of these shops? All listed in the thomas register under zinc plating:
https://www.thomasnet.com/suppliers/discover/tennessee/all-cities/serving?searchterm=Zinc%20Plating
Old 11-12-2025, 04:16 AM
Only one listed on that site and they don't do car parts. There is another one that has bad reviews on other websites.
Old 11-12-2025, 06:07 AM
Brickwhite's Avatar
replate at home... its easy.
Old 11-12-2025, 07:32 AM
I went with new. It wasn't that much more than replating. I subbed the job out and that is was Al recommended too.
Old 11-12-2025, 07:47 AM
Why would you spend $300 or more to plate a few parts at home. Not to mention sodium dichromate is a carcinogen
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 11-12-2025, 09:05 AM
Brickwhite's Avatar
you can just Zinc plate, you don't need Sodium Dichromate. should cost about $50 all said and done. It won't be show yellow quality but it will hold up against Rust.
Old 11-12-2025, 09:09 AM
I tried acid etching and spraying a circa 1980 galvi horse barn roof. Worked for perhaps two years. Put the same on that barn as the four car in the pic. Couldn't be happier.
Old 11-12-2025, 12:44 PM
You have no idea what your talking about.
Old 11-12-2025, 03:02 PM
I've decided to go the easiest route and ordered a new set of spring plates from our host. With no idea how long it might take to find a company to do the plating and how long get the parts back, this is just way easier. I can sell the bushing that I already bought as well.
Thank you for all the input!
Old 11-12-2025, 05:00 PM
ericwitte's Avatar
Send a message via AIM to ericwitte Send a message via Yahoo to ericwitte
I used the Eastwood paint that looked like cad plating 20 years ago and still holding up…
996 Coupe, 84 Euro Carrera, Cayenne S, BMW CS 30, 72 2002 Ti (gone)
72 911 Hot Rod, Healey 100M, Giulia 1300 Ti, Merc 280SE4.5
Colorado Grand 03-04-05-07-08-11-17-18 Tour Auto 04-05
RG #650
Old 11-12-2025, 07:41 PM
