Common sources of door rattles
Hi guys - hope everyone is having a good weekend. I was hoping to get some coaching on where to hunt down my passenger side door rattle. This is for a '74 so no power mechanism.
I have the door card off but can't seem to find where the rattle is coming from. It is persistent at highway speeds.
Thanks!
1967 912 (now w/ 50% fewer random holes in it)
911 w/ 3.2
1974 914 (3.2L swap underway)
1984 928s (S4 engine and suspension), 1987 928S4
Old 03-19-2017, 08:07 AM
Look at the metal bar/shaft running from the interior door handle to the latch. It should be supported along its route by some type of "insulators" that keep it away from the interior metal frame. I can't remember exactly where or how many, or if they are plastic or foam, but I do remember seeing them as the bar passes closely to the framing.
Another place to look is at at the locking shaft, running from the button near the front of the door top to the rear where the lock/latch is located. It too should have some isolation from hitting against the door frame.
Finally, the door window mechanism should also be secure with the lifting arms not being able to vibrate against each other.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 03-19-2017, 08:19 AM
Thanks, will check those out.
Hope you have a good rest of the weekend.
911 w/ 3.2
Old 03-19-2017, 03:35 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Coupe or Targa?
Old 03-19-2017, 04:10 PM
Originally Posted by DRACO A5OG View Post
Coupe or Targa?
Oops, coupe.
911 w/ 3.2
Old 03-19-2017, 07:36 PM
Check the mounting for the window frame.
On my car, the small mounting plate and bolt (closest to the speaker hole) was installed incorrectly and causing the rattling.
I would also add self adhesive rubber foam pieces where the locking rods are.
Hope this helps.
Scarface
Old 03-19-2017, 11:10 PM
Did you checked your door strikers?
Usually if broken they produce the rattles you describe.
Stoddard produces a rebuild kit:SIC-531-701-31
Do not know if it's available to our host
Old 03-20-2017, 01:14 AM
MBAtarga's Avatar
Is one of these in the door bottom?
Mark
'83 SC Targa - since 5/5/2001
Old 03-20-2017, 05:10 AM
Counterclockwise?
Ha! I found one of those in my door just yesterday!
Now I know someone has been in there before me.
Rod
1986 Carrera
2001 996TT
Old 03-20-2017, 11:14 AM
Hi Rod & Mark,
I found one of those in my door, did you find which part its from? My door locking mechanism and my window are both still working…
Old 11-27-2021, 10:11 PM
Captive nuts along the door bottoms.
206 637 4071
Old 11-27-2021, 10:57 PM
proporsche's Avatar
it goes here at the pic ,where the spring s
https://cdn02.plentymarkets.com/ee5vntdimm3u/item/images/1469/full/parallel-fensterheber-rechts-mechanisch-porsche-911-91154204200-1-.jpg
1985 911 with original 502 191 miles...808 198 km
Old 11-28-2021, 01:28 AM
Bill Douglas's Avatar
The 10mm socket you lost a few years ago is rolling around the bottom of the door.
Look at the metal bar/shaft running from the interior door handle to the latch. My rattly door was the same problem as Ossiblue describes.
Old 11-28-2021, 09:33 AM
proporsche's Avatar
also the rattle is common on the wheels are dry inside the rails.....any grease will help,i use Sachs lubricant ...
Ivan
Old 11-28-2021, 10:39 AM
I just found this thread doing a Google lens search. I found one of these loose in my door too. Can anyone elaborate on where it goes? The image link above is broken.
Old 11-22-2025, 04:11 PM
40 year old plus car! I just drive with my hearing aids turned off!!
Old 11-23-2025, 10:39 AM
'87 Targa
Several threads about this. Here are just a couple:
https://forums.pelicanparts.com/porsche-911-technical-forum/1153558-window-regulator-pins-87-a.html
https://forums.pelicanparts.com/porsche-911-technical-forum/664473-slow-window-fix.html
Old 11-23-2025, 11:21 AM
